7.3 Running odd
Old Oct 25, 2011 | 12:45 PM
bass-n-fire's Avatar
bass-n-fire
7.3 Running odd
Over the past couple of weeks my truck has been idling rough intermittently. Sometimes I'd be driving down the road and you could feel it start bucking. Sometimes when you first start it, the CEL would come on, turn it off and restart it and it would go off. Here recently it would just die. Checked and replaced both batteries this morning. That seemed to fix it for a while. Then she up and died. Any suggestions? I need help badly.
Old Oct 25, 2011 | 12:47 PM
bass-n-fire
Forgot to mention, when she dies she will start right back up.
Old Oct 25, 2011 | 12:56 PM
fordpride's Avatar
fordpride
Sound like a CPS but I'm not sure if it would set a CEL
Old Oct 25, 2011 | 03:11 PM
bass-n-fire
Update.....
After replacing the batteries, the CEL has not come back on. Even after dying and all the bucking it has done today.
Here is what it has done or is still doing. It died while I was driving down the road and it is bucking really hard.
I just bought a new CPS, but that will have to wait until the engine cools. The guy at the parts store said it could be a fuel pressure problem. How do I go about checking the fuel pressure and what should it be?
Old Oct 25, 2011 | 04:34 PM
tshrager's Avatar
tshrager
Originally Posted by bass-n-fire
Update.....
Schraeder valve on the FPR. Should be between 55-75 psi @ idle
Old Oct 25, 2011 | 04:45 PM
BuckHammer's Avatar
BuckHammer
It sounds like a CPS problem to me.
Old Oct 25, 2011 | 08:14 PM
LeoJr's Avatar
LeoJr
Just replaced the CPS yesterday morning for similar symptoms.
Performed the work from below. From the top was very tight and I didn't have time to figure out how to get the serpentine belt off, much less back on correctly!
Took me 30 minutes this time. Will take me 3 minutes the next.
I'm not confident this fixed my problem, by as this was the first service I've done other that add diesel to the tanks, it has boosted my PSD wrenching confidence!!
Old Oct 25, 2011 | 08:15 PM
LeoJr's Avatar
LeoJr
Old Oct 25, 2011 | 08:44 PM
LeoJr's Avatar
LeoJr
Old Oct 25, 2011 | 10:58 PM
oldbird1965's Avatar
oldbird1965
LeoJr, did you get your CPS from Ford's?
Old Oct 26, 2011 | 05:10 AM
drivembig's Avatar
drivembig
That sounds very similiar to what my truck is doing. When I first start the truck up it will buck going down the road and even die. When I start it back up it smokes really bad and acts like it will not take fuel or isn't getting any fuel. After a few minutes it will stop smoking and start reving clean again. After the truck warms up it runs perfect again. I was wondering about oil pressure in the high pressure pump. My guage shows pressure, but I don't know about the high pressure. I still can't understand the smoking though.
Old Oct 26, 2011 | 07:16 AM
LeoJr's Avatar
LeoJr
Yes, it is a black Motorcraft part with a blue o-ring.
Old Oct 26, 2011 | 08:52 AM
oldbird1965
That's the good one.
Old Oct 29, 2011 | 06:56 PM
bass-n-fire
Update...Replaced the CPS. Truck smoothed out a lot. The bucking is still present, however, it only does it every once in a while now. Not throwing any codes. Checked fuel pressure and I'm getting 50-55 psi at idle. Any other suggestions would be greatly appreciated.
And thanks for allof the input so far.
Old Oct 29, 2011 | 07:18 PM
BuckHammer's Avatar
BuckHammer
Did you check the wiring to the CPS?
