bed floor
Old Nov 7, 2011 | 06:38 AM
664x4drvr's Avatar
664x4drvr
bed floor
If I hammer the big dents out of my bed floor, will I regret using fiberglass on the rest of the dents to make it look really good ? are there any better choices?
Old Nov 7, 2011 | 06:48 AM
OverReved's Avatar
OverReved
Unless you are going for a show truck, or a true restoration, I'd through a bedliner in there and be done with it. If you get a name brand that's for your year and model, it will look great. In the mean time you may run across a bed in decent shape that you can work on at your leisure and swap it out when it's ready. Just an idea.
Old Nov 7, 2011 | 11:20 AM
huckdeuceman's Avatar
huckdeuceman
You could go with a spray in/roll on liner? they are kinda thick coatings and may fill the small dent's to you satisfaction? if you get a good rough finish it may hide pretty well?
Check too see what coatings are the thickest and go from there!
Old Nov 7, 2011 | 04:34 PM
Layne's Avatar
Layne
You'll definitely regret using fiberglass.
Old Nov 7, 2011 | 06:15 PM
carras's Avatar
carras
I flipped my bed over and used an air hammer. I found a 'chisel' attachment for mine that was pretty much just the shank. It helped me get even the smallest dimples out. Certainly not show quality, but good enough for my needs. Good luck -
Old Nov 7, 2011 | 07:53 PM
tomrooster-1's Avatar
tomrooster-1
I hammered mine out then used a filler for the ones I couldn't get to and it's not perfect but looks OK
Old Nov 7, 2011 | 07:59 PM
664x4drvr's Avatar
664x4drvr
Tomrooster-1 what is in the left inner fender ? is that your gas filler?
Old Nov 8, 2011 | 07:54 PM
tomrooster-1
664x4drvr, yes that's my gas filler,66 on 75 frame, there wasn't room on the side to fit it in. Tom
Old Nov 8, 2011 | 07:57 PM
tomrooster-1
Old Nov 12, 2011 | 07:43 PM
664x4drvr's Avatar
664x4drvr
1966 bed
Has any one used the 16in x 4 ft bed floor panels that are weld in ?
BaltoMoJoe
Dec 15, 2014 06:52 PM
cujo8
Oct 9, 2006 07:41 AM
ahawes
Dec 19, 2005 08:46 PM
restoringmy46
1947 and Older Ford Trucks
Jan 21, 2005 11:22 PM
