thinking about putting some ford or crane 1.7 roller rockers in my 1986 F150 302 4-speed
any body done this?
worthwhile? horsepower? torque? easy installation?
can I use the original valve covers
let me know about your opions and experiences
any body done this?
Yes, it's worth while. Not only will you pick up some power from the increased lift, but you'll pick up even more from the decreased friction. Roller rockers are good for 15-20 hp due to the friction loss and the ratio stability ( they don't flex) They'll fit under the stock valve covers. Installation is easy too, just bolt them down and torque them to 25 ft/lbs.
He'll have no clearance issues swapping to 1.7's, they only increase the lift by about .030". And you don't need a roller cam to run with them. Guy's running race motors were using roller rockers with flat tappet cams long before roller cams became commonplace. And they still do. I ran a set of "Cobra" 1.7 rockers on a std 5.0 from an 88 Crown Vic in my 89 Ranger with no problems whatsoever. And it's not just me that suggests it , Ford does as well in their book "The Official Ford Mustang 5.0"
You may have problems with the original valve covers. Stacking gaskets and removing internal baffles may be required. Valve to piston clearance is a non-issue with stock low-compression pistons and the stock mild cam.
As for the valve cover issue, the "Cpbra" roller rockers fit under the low profile steel covers used on the 90's 5.0's. Those are the covers the Cobra motors had.
They'll work on all 5.0's from the 78's up to the end of production in 2001. They're the "bolt down" type and are direct replacements for the stamped steel stock rockers used on those year's motors. If you're putting them on a roller cammed 5.0 with high miles ( 75,000 - up) I'd also recommend changing the pushrods too. The roller cammed pushrods don't rotate like the flat tappet ones do and as a result get worn to a "knife like" edge at the rocker end.
I don't believe that I have a roller cam in my 96 5.0. So the 1.7 rollers are direct replacements and should bolt right down, no need for a new valve cover and just use a new gasket. Do you recommend replacing the push rods with new ones? Like you said "high miles". i'm seriously thinking of doing this this weekend. a few extra horses won't hurt and I can use them on the new motor (when i do the rebuild). and last you did say the rollers are used on the cobra 5.0?
All,
Why would a 1.7 ratio arm help you?
1. The intake valve is too small. Increase valve lift, increases the cross sectional area around the valve.
2. Valve duration does not change. This means the valve opens and closes at the same time. You should see no change in idle characteristics.
3. So, if the intake flow charateristics are limited by a restricted intake valve size this would help.
4. If the restriction is in the intake manifold, mass airflow or filter box arrangement, you probably will not see any change.
5. Is reduced friction a viable source for effiency gains? Yes it is. How much can you gain by switching to roller rockers. In my opinion, the change will be unoticable.
I would bet that changing to a K&N filter system would show you more gains. once you have allowed more flow through the motor, you will have to figure the next restricting element. It is a house of cards and can challenge even the best test & tuner.
Lastly, if you notice gains, they are most likely from a undersized intake valve with respect to manifold system.
Good luck,
KingFisher
All,
The valve duration does slightly increase with increased valve lift, but not significantly. I beleive 1.6-1.7 increase would bring another 2-5 deg. duration @ .005" tappet lift. Like I said, hardly significant.
4. If the restriction is in the intake manifold, mass airflow or filter box arrangement, you probably will not see any change. Less than 1/8 of the airflow restriction on 4-cycle motor is before the cylinder heads.
What he can expect though is a motor that sounds quieter at idle, and will probably increase the redline of the motor. I've installed Crane roller rockers on my vehicles, as well as many of my friend's, and they are always worth it. Even on LT-1 Camaros, the difference is noticable in idle noise, and at high-RPM pulls.
Good luck,
KingFisher
I'd stay away from a K&N with your EFI. Do something worthwhile like a pair of Flowmaster Super 40's, or an MSD ignition upgrade.
I agree with Fisher about the subtleness of the improvement, but from experience I know that Crane roller rockers are truly one of the finest bolt-on for the money.
I've done lots of chevys but never a ford. are the rockers mounted on a bar or studs? if they are direct replacements for the stock rockers do i need to replace the springs to? seeing that the motor has 128k on it. and last should i put new pushrods on while i'm there?
