3g alternator help?
Feb 12, 2012 | 12:34 PM
Wasn't too bad. He cut the wire back to where the fitting slipped on, heated the end with the prop torch, and put in the solder.
After it cooled we put on the heat shrink wrap.
Feb 12, 2012 | 01:36 PM
sweet so its just gonna be locating a mounting point that works for me
Feb 12, 2012 | 02:50 PM
Mine fit right in where the 2g used to be without any modification. Just unbolt 1, change in the new one.
Feb 12, 2012 | 02:53 PM
lol i i know that i got the large case though im gonna have to grind out the bracket a little. i was refering to the fuse. i saw the photos you put up of having it on the fender i think im gonna try for that i dont know ill see how it plays out.
Feb 12, 2012 | 02:56 PM
I'd put the fuse on the fender, less vibration/ heat there
Feb 12, 2012 | 03:00 PM
also water protection!! i also had to order a pigtail for my fuel pump relay due to moisture it coroded and started to heat up!!
Feb 12, 2012 | 03:06 PM
That pigtail has been replaced twice on my 89. Normal wear and tear believe it or not. make sure to goop everything up with dielectric grease
Feb 12, 2012 | 03:12 PM
yes!! dielectric is my friend on this truck!!! if i can put it on there it goes on i dont care what it is lol
Feb 12, 2012 | 03:21 PM
I have a can of cnc contact cleaner I spray everything down with first. Then goop it all up.
Feb 12, 2012 | 03:30 PM
yea crc has some good products. fun fact: their electric parts cleaner tastes horrible!!!
Feb 12, 2012 | 03:43 PM
Thanks for that tid bit, I probably never would have known other wise.
sending "taste" reps, lmao
Feb 12, 2012 | 03:55 PM
yea thanks gravity was in affect at the time!!
Mar 11, 2012 | 04:49 PM
ITS ON!!!!!!!!!!!!!!! FINALLLY I GOT IT ON!!!!!!!!!!!! ill have pictures up soon!!! i finally did it!!!!
Mar 11, 2012 | 05:05 PM
Congrats Kris.... now start it!
Mar 11, 2012 | 05:12 PM
haha yea ive been runin the truck for two weeks since i put it on i am just now getting around to posting about it!!!! lol
