dash gauge lights not working??
Old Nov 5, 2011 | 10:01 PM
chad85's Avatar
chad85
Exclamation dash gauge lights not working??
Got a little issue with my 78, when I turn the headlights on, the dash gauges are not lighting up. Everything else works, such as the headlights, taillights, even the a/c and heat control backlighting works, just not the backlighting on the gauges.....any idea what the problem could be???
Old Nov 5, 2011 | 10:05 PM
fmc400's Avatar
fmc400
MSEE
The heater control lights are on the same circuit as the instrument panel illumination (gauges), so if those don't work, it's isolated to the instrument panel itself. This takes the fuse and headlight switch out of the equation.
Check the back of the instrument cluster. The bulbs are installed using small carriages that lock into place. Check these contacts for corrosion. You could also simply have burnt out bulbs.
Old Nov 5, 2011 | 10:13 PM
chad85's Avatar
chad85
Oh, forgot to add that I changed all the bulbs and it did not fix the problem
Old Nov 5, 2011 | 11:04 PM
wyckedcombo17's Avatar
wyckedcombo17
Those lights are wired in parallel, so it is a common point issue.
Looks like those all ground to the same point, so its somewhere before ground and after the power source
Old Nov 6, 2011 | 07:21 AM
fmc400's Avatar
fmc400
MSEE
What about my other suggestion then?
Sam A
16
Jun 8, 2020 05:41 PM
ScottyC50
Sep 2, 2018 10:19 AM
kyle1979ford
Oct 5, 2013 08:19 PM
charlie branham
May 5, 2012 08:34 PM
GeneStoner
Jan 15, 2005 02:00 AM
