Oil temp
Old Nov 14, 2011 | 11:22 PM
BLADE35's Avatar
BLADE35
Originally Posted by LSAtexan4x4
well imma go for a drive to get some dinner and i will post exact numbers when i return... those pics are gnarly!!!! did you go with the bpd cooler?
No I went back with OEM cooler
I flushed its guts out then ran a coolant filter for 5000miles with a coolant filter change in there
then another round of flushing right before I changed the oil cooler and new coolant filter
this time of year I see 4-6 degree spread
in the heat of the summer 95*+ 6-10* spread so far
Im not worried If it plugs up again I will change it wasnt to bad in the driveway I was a little slow 4 days with a full egr deleate & oil cooler rebuild and some other stuff
Probably do it over a weekend again if the time comes again Im nit picky and triple check everything and make it spotless
Old Nov 15, 2011 | 12:15 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Make sure your temp readings from the SGII read nearly the same after a cold soak.
Old Nov 15, 2011 | 07:47 AM
LSAtexan4x4's Avatar
LSAtexan4x4
Cold soak? What's that like rain?
Old Nov 15, 2011 | 09:53 AM
BLADE35's Avatar
BLADE35
Rain LOL
cold soak is letting the truck sit for 12 hours or more all temps should be the same ECT and EOT and TFT
It verifys the gauge accuarcy
Old Nov 15, 2011 | 10:02 AM
draboo's Avatar
draboo
A question about this cold soak: Will the scanguage2 check these temps without the engine running, or can you check em with just the key on?
Truck has been sitting since 8 pm last night. It is 30 degF this morning, so I m assuming it has been soaked pretty well!
Old Nov 15, 2011 | 10:20 AM
BLADE35's Avatar
BLADE35
that should be long enough
Check them right at startup Immediatly
Old Nov 15, 2011 | 08:11 PM
duckymax's Avatar
duckymax
I don't know where to go from here? I changed my oil cooler, thermostat, oil temp sender, and I still have a 40 degree difference. Any ideas? When I checked the temp I would drive to town (stop and go for 10 min) then hook up scanner drive highway 60 - 70 mph for 5- 10 min. Am I not driving long enough on highway to equalize temps? Any sugestions?
Old Nov 15, 2011 | 08:28 PM
BLADE35's Avatar
BLADE35
you need to take the spread when the temps max out after the coolant hits 190*
what were your numbers
Old Nov 15, 2011 | 08:42 PM
steelhead2's Avatar
steelhead2
Did you do the vc9 flush ducky?.sounds like it may have plugged up again.search oil cooler backflush and do it asap.mine went 500 miles and plugged again.I ended up putting in a radiator to.luckily backflushing my cooler saved it.one other thing,what are your temps after sitting all night?.your scanner should read them key on engine off.in town my temps are 2-3* difference stop and go driving.freeway at 60 they're 5*,65 is 7*,70 is 8-9*.
Old Nov 15, 2011 | 09:00 PM
duckymax's Avatar
duckymax
The temps were 185-7 and 230-236. Do you think it's possible it pluged up after 20min fast idle, sat overnight then went to town? And if so can I use vc9 again without hurting anything?
Old Nov 15, 2011 | 09:14 PM
BLADE35's Avatar
BLADE35
Man thats very fast for it to plug again
Verify after cold soak that all fluid temps are the same or within a couple degrees ECT & EOT & TFT
I think there may be something eles going on here water pump issue front cover cavitation
You maynot be getting good coolant flow
Old Nov 15, 2011 | 09:29 PM
duckymax's Avatar
duckymax
Do you know of any way to check for coolant flow?
Old Nov 15, 2011 | 09:45 PM
  #28
BLADE35's Avatar
BLADE35
I do not know of a way to check for flow
Did you flush it good before you changed the oil cooler out
Old Nov 16, 2011 | 12:56 AM
  #29
Dieselpop's Avatar
Dieselpop
When i did my coolant flush i used 48 gallons of distilled water 1/2 gallon of Restore then 5 flushes then 1/2 gallon Restore+ then 6 flushes 12.5 hrs of my time 1/4 tank of fuel 3 1/2 gallons of Delo ELC coolant they said it was over kill but it is clean with deltas of 4-6* here is the flush i used.
Flushing and cleaning the 6.0
Restore is for cleaning out any silicate goo. VC-9 is for cleaning out iron and scale. Restore Plus is the same as VC-9 and cheaper.
To flush drain the coolant by removing the lower radiator hose from the radiator, and removing the drain plug from the driver side of the block. There is a drain plug on the passenger side also but you have to remove the starter to get to it. I don't bother with that one.
I also highly recommend you pull the thermostat out on your first drain and put the housing back without the thermostat. It only takes about 10 minutes and will save you 2.5 hrs or so in doing this whole procedure.
Ok now put the lower hose back on and the drain plug back in the block if you removed it. This is the procedure you will use each time to drain the system, except you will not touch the thermostat again until you're finished the whole procedure. Make sure that you set your heater to high while doing this to flush out the heater core as well.
Fill the cooling system with distilled water, start the truck and let the water circulate for 5 minutes. (if you did not remove the thermostat you must run the truck until the thermostat opens + 5 minutes to circulate. This takes 15 to 20 minutes each cycle and is why you should just remove the thermostat) Stop the engine. Drain the system and repeat the flush.
Now add at least 1/2 gallon of Restore and fill with distilled water. I used cardboard in front of the radiator because you have to get to 185* 190* for these products to work. Drive truck or run on high idle for 60-90 minutes just before you get back from your drive remove the cardboard this will help in the cool down same on the Restore+ flush. Drain and flush 3 or 4 times. or tell clean
Add 2qts VC-9 or 1/2gal of Restore Plus, top with distilled water, and drive the truck or run on high idle for 60-90 minutes. Now drain and flush until flush water comes out clear and clean. When you get clean flush water, flush 3 more times using distilled water while draining the block.
After your final distilled water drain it is time to put the thermostat back in. I recommend you install a new thermostat at this point. They are only $20 or so and it is good maintenance procedure to do so. Fill with 3.5 or 4 gals of ELC concentrated coolant and top off with distilled water. Drive the truck or let run for a while topping off with distilled water. Check the truck over the next few days and top up as required while any air left in the system works its way out.
Keep some 50/50 ELC on hand to use to top off the cooling system from here out and you are good to go.
new t/stat from Ford it should all come together (housing-t/stat-o-ring) in a box. The part number is RT-1169
Here is the Restore Product from Cummins dealer
http://www.fleetguard.com/pdfs/produ...LI33024-GB.pdf
pop
Old Nov 16, 2011 | 09:20 AM
  #30
LSAtexan4x4
There is a shorter procedure I believe.. But yours sounds adequate... I need to do mine soon
