AC Pully Locked up...How to replace?
Old Nov 5, 2011 | 06:21 PM
dpolland's Avatar
dpolland
Last night my 2004 F250 6.0 broke the belt. Upon inspection I found the pully on the AC unit not able to spin. I confirmed the clutch plate did spin. I can't find any instructions on removal and replacement. If I can't get it done myself, I will have to have it towed to a shop on Monday. Can anyone describe the steps of replacement and also in the event I have to send it to a shop, what I should expect to pay for the repair?
Thank you
Old Nov 5, 2011 | 07:01 PM
cheezit's Avatar
cheezit
better off replacing the compressor as a complete assmebly. odds are its locked up. you need to evac the system and check the orface tube for metal.
to remove you can pull the fan and stator, rmove the ground from the engine block and remove the 3 bolts that hold the compressor on to the engine.
cost for repair of an a/c system is hard to guess at not knowing what all is broken. Ill toss a guess though $1500-2200 depending on what you need.
Old Nov 8, 2011 | 01:04 PM
dpolland's Avatar
dpolland
Fixed and working great!
The clutch was replaced. The AC compressor was just fine and did not need replaced as you may have thought.
Old Nov 8, 2011 | 07:08 PM
Maxium4x4's Avatar
Maxium4x4
Welcome to FTE dpolland Glad you found the problem and are back up and running. It is hard to diagnose a vehicle when it is not in your possession, so we try and help as much as possible.
75_92_95
Jul 15, 2011 06:10 PM
scotts630
1997 - 2003 F150
Aug 1, 2010 03:08 AM
BOBSDIESEL
Feb 27, 2009 09:35 AM
Joyride93XLT
Jun 9, 2006 10:12 PM
turboguy
Mar 18, 2005 11:09 PM
