Blinker changes RPM's
Old Nov 5, 2011 | 01:28 PM
tkerkela's Avatar
tkerkela
Question Blinker changes RPM's
Hi, I have a 1992 Ford F-150 Flareside with a 5.0, I have this issue when I use my turn signal the trucks RPM's increase and goes to like passing gear. I have no idea what the blinker has to do with the engine RPM's and think this issue is very weird. If anyone has any idea why and or how to fix this it would be much appreciated. Thanks.
Old Nov 5, 2011 | 01:53 PM
rla2005's Avatar
rla2005
Check and clean the ground on the radiator support (G100 LH front of engine compartment, on upper radiator support) and the chassis ground located near the battery (G101 RH front of engine compartment, front of fender apron). Locations are referenced from the driver's perspective.
Old Nov 5, 2011 | 02:29 PM
86F150302's Avatar
86F150302
The blinker turning on is causing the torque converter to unlock. Try replacing the bulbs.
Old Nov 5, 2011 | 04:45 PM
rla2005's Avatar
rla2005
Very good suggestion...
Old Nov 7, 2011 | 06:31 PM
86F150302's Avatar
86F150302
Thank you
So tkerkela did you fix your problem??
EllieMae94
Jun 28, 2024 05:32 PM
john fin
Dec 13, 2011 12:30 AM
barryf
Oct 11, 2011 07:27 PM
grandaddy's66
Aug 13, 2005 08:42 PM
cpe41
13
Feb 5, 2005 07:45 PM
