Radiator Support Ground Strap?
Old Dec 22, 2018 | 07:03 PM
EllieMae94's Avatar
EllieMae94
When I purchased my truck over 2 years ago one of the first things I noticed was a ground strap that was cut. I removed the clip and short 1/2" piece of strap that was attached to it, somebody had cut it clean off. I forgot about it and now want to replace it. If memory serves me correctly, it was clipped on to the radiator support ( I can't remember if it was driver or passenger side). Is this correct, and if so, where does the other end of it attach to? Thanks everybody!
Old Dec 27, 2018 | 01:17 AM
TexasGuy001's Avatar
TexasGuy001
Almost sure it is on the passenger side connected between the radiator support and the crossmember that looks like a skid plate for the steering linkage.
Old Dec 27, 2018 | 07:23 AM
subford's Avatar
subford
Having Radio static problems?
That is why the anti static ground strap was installed for.
Old Jun 28, 2024 | 05:32 PM
Jett poz's Avatar
Jett poz
1st Gear
you are correct but my crossmember had to be removed because it was damaged and it’s kinda redneck attached. Could I attach the ground onto my frame instead?
barryf
Oct 11, 2011 07:27 PM
Jeff and Nicolle
Dec 22, 2010 11:10 PM
frankydabull
1947 and Older Ford Trucks
Mar 8, 2004 06:14 PM
