Greetings, y'all. I am in the process of replacing a radiator support on a 1995 F-150 and I am in a nine-line bind.
I need to get the plastic piece off that the headlights and signals moumt to. There are 8 bolts holding it on and I have 6 off. There are two behind the turn signal (not the marker lights). It looks like I need to get the yellow turn signal off, but darned if I know how - it looks like the screws that hold the assembly to the bracket are inside it!!
I'm two-blocked and need a little help. Thanks, fellers!!
I did. Even before I started this thread. It gave me a ton of hits, most of which did not help. I will try a search with his username.
The heck of it is I almost have it done......
