What could be the problem?
Old Nov 7, 2011 | 05:06 PM
brcwelding's Avatar
brcwelding
I have 2 new fuel pumps and a new fuel filter and still no fuel. I thought it was a spark problem but i took the plug out and had somebody try to start the engine and i saw it had a strong spark. If both my in tank and high pressure pump are working then what could the issue be?
Old Nov 7, 2011 | 05:29 PM
bashby's Avatar
bashby
First off, what are you working on? Do you have no fuel pressure or just an engine that wont start? Can you hear the pumps run?
Old Nov 7, 2011 | 06:26 PM
brcwelding's Avatar
brcwelding
Im working on an 88 f250 351w. I can hear both fuel pumps running when i turn the key. It is dual tanks by the way.
Old Nov 7, 2011 | 06:33 PM
bashby's Avatar
bashby
Next thing I'd do is spray a little shot of starting fluid or carb cleaner in the throttle body to see if it will fire. If it does, check for power to the injectors. The computer grounds the injectors for a split second at a time to pulse them open. Sometimes the computer goes bad and quits doing that.
mrplumber
23
Jun 18, 2011 07:00 PM
shadetree2070
19
Feb 2, 2011 03:08 PM
conradcliff
38
May 29, 2010 07:27 PM
vee-eight-fords
13
Feb 3, 2004 04:41 AM
fordchickneedshelp
Nov 17, 2002 10:34 AM
