what would cause a code PO605?
Old Nov 4, 2011 | 04:16 PM
90pioneer's Avatar
90pioneer
99 7.3. Getting code P0605 on cold morning starts only. Will not start. After its warmed up or plugged in, starts and runs fine.
P0605 is "internal control module ROM error"
Assuming the wiring harness for the PCM is in tact and all the grounds are good, could anything else besides a bad PCM cause this code?
Old Nov 4, 2011 | 04:25 PM
ToMang07's Avatar
ToMang07
603/605 can be caused by removing fuses, disconnecting batteries, changing programs, or a flip-chip. Could also be a PCM problem, but that's pretty rare.
Old Nov 4, 2011 | 04:28 PM
90pioneer's Avatar
90pioneer
If I don't have a flip chip, haven't changed any programs, disconnected batteries or pulled fuses, would it be safe to assume my PCM is actually bad?
Old Nov 4, 2011 | 04:36 PM
ToMang07's Avatar
ToMang07
Generally speaking, if your scanner is communicating with the PCM... the PCM is good. What is it doing, other than the code, and what are you using to scan it?
Is the Wait To Start (WTS) light coming on off like normal?
Have you pulled/checked your fuses?
Old Nov 4, 2011 | 04:41 PM
90pioneer's Avatar
90pioneer
The WTS light functions as normal. Not sure on the scanner, the international dealer pulled the codes.
The truck will only crank when its cold, will not start. When warm or plugged in it starts fine and runs great.
My GPR is brand new, all my glow plugs test good, and the passenger side has 4 new glow plugs and a new UCV harness. Glow plug system "functions perfectly" according to the international dealer.
Old Nov 4, 2011 | 04:42 PM
90pioneer's Avatar
90pioneer
What fuses should I check?
Old Nov 4, 2011 | 06:31 PM
bluescrew's Avatar
bluescrew
every one you can find!!!
omar1746
Mar 15, 2016 08:43 PM
hammer65
Aug 25, 2012 05:50 AM
forumsearcher
May 31, 2012 07:04 AM
EFLBIKER
Sep 3, 2009 06:21 PM
HVJ
Dec 27, 2004 10:35 AM
