Code Help!!!
Old Sep 3, 2009 | 12:49 PM
EFLBIKER's Avatar
EFLBIKER
Code Help!!!
<TABLE class=code_result_table><TBODY><TR class=code_result_head><TD>Code</TD><TD>Make</TD><TD>Description</TD></TR><TR><TD>P0672</TD><TD>Generic</TD><TD>Cylinder 2 Glow Plug Circuit</TD></TR></TBODY></TABLE>
code reader = Innova 3100
Long time lurker and friend of the search function, but now I need a little more help. code reader = Innova 3100
My 2002 7.3 Excursion thru this code today. It seems to start and run fine.
what do i need to do to fix this?
I’ve had the Ex for about a month so I’m new to diesels and am trying to learn.
<O</O
Thanks
Old Sep 3, 2009 | 02:23 PM
EFLBIKER's Avatar
EFLBIKER
nevermind i searched a little harder and found it
Old Sep 3, 2009 | 06:21 PM
F350-6's Avatar
F350-6
So are you going to test the wires or just change the glow plug? Have you caught the hint about avoiding autolites? Are you going to go ahead and retorque the rocker and injector hold down bolts if you pull the valve covers? Maybe shim the UVCH?
No need to hide in the back ground all the time. Welcome to FTE.
trippn4re
23
Jun 2, 2014 04:16 PM
Mr.250
Nov 5, 2011 08:19 PM
morrisjl2
General Diesel Discussion
Apr 30, 2009 03:00 PM
indebt
Nov 7, 2008 09:29 PM
Bowie
Nov 6, 2008 03:05 PM
