ATF fluid
Old Nov 4, 2011 | 09:03 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Originally Posted by XB70
Mike Kolvasky says it's compatible with SP, and that's good enough for me.
Who's he?
Old Nov 5, 2011 | 05:16 AM
XB70's Avatar
XB70
Originally Posted by Mark Kovalsky
Who's he?
Some guy I read about on this forum who types better than I!
Old Nov 5, 2011 | 06:25 AM
kbf1961's Avatar
kbf1961
Thanks fellas. I will be returning the Mercon V I bought..DOH!
Old Nov 5, 2011 | 08:36 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
When Mercon LV came out, it was stated that it is compatible with Mercon SP and could be mixed.
However, if and when I need to change over to "LV", I will do a flush to ensure I get all of the old "SP" out first.... why, becuase I just don't buy or understand how two different spec'd fluids can work together properly... each has it's own spec and I get it... but two specs together causes me concern.
This is why I only use single spec fluids (even in my powersteering system) and I do not mix oils between summer and winter (I just use Rotella Syn 5W-40 year round - since 3qts of old oil always stays in the high-pressure oil system).
Old Nov 5, 2011 | 09:55 AM
69cj's Avatar
69cj
You can use 3 or 4 of those qts. of Mercon V to flush your power steering system. Then add a a filter on the return line. Good ins.
EMC V10 X
Jan 21, 2011 09:59 AM
Aggie588
Mar 5, 2010 03:48 PM
1978Crew
Escape & Escape Hybrid
20
Jan 2, 2008 07:25 PM
JBB1073
Nov 1, 2002 12:24 AM
