Sponsored by: Real Truck
ATF fluid
Old Mar 4, 2010 | 01:29 PM
Aggie588's Avatar
Aggie588
ATF fluid
In the parts store the salesman said, type "E" transmission fluid is the same as Mercon V, question-is he correct?
Old Mar 4, 2010 | 02:39 PM
Hybris's Avatar
Hybris
Not 100% but I'm fairly sure that SD's use type F.
Old Mar 4, 2010 | 05:30 PM
mwsF250's Avatar
mwsF250
The 4R100 requires Mercon fluid, not F. I believe type F has not been recommended for Ford trannies built since '87 or so....
Mercon is obsolete now, so Mercon V is the commonly recommended replacement.
http://www.aa1car.com/library/ford_tsb_06144.pdf
Some debate whether Mercon V is as ideal as Mercon, but it's what is commonly recommended.
I'm not familiar with type E. Is this possibly referring to Dexron IIE or Chrysler 7176E fluids?
Read the bottle. If it explicitly says it meets Mercon, you should be OK.
Old Mar 5, 2010 | 03:25 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
If it explicitly says it meets MERCON V you should be OK.
Old Mar 5, 2010 | 03:48 PM
cmiller1229's Avatar
cmiller1229
Mark,
E40D Takes what Tranny fluid?
