keypad code
Old Nov 3, 2011 | 02:50 PM
trucktech's Avatar
trucktech
keypad code
i did some searching and from what i found is the early years of the keypad didnt come with a code hidden on the vehicle? and how do i go about getting it and does the dealer charge for this? thanks 2000 v10 excursion limited
Old Nov 3, 2011 | 03:06 PM
Grandpakent's Avatar
Grandpakent
Search this forum for the thread on door codes. You can then download a list of all of the five number combinations. Using this list you try each one until it works. I did it and found the code, wish I could say on the first page but I had to keep punching until almost the end. Good luck to you.
Old Nov 3, 2011 | 03:11 PM
Fishing_Uncle's Avatar
Fishing_Uncle
Here is an old link I had saved. I think there was a better organized one on here though.
Weak security in our daily lives@Everything2.com
And as far as the dealer charging it all depends on the individual dealer.
Old Nov 4, 2011 | 01:54 AM
robert_l_ross's Avatar
robert_l_ross
Didn't search this forum though, huh?
I posted a compilation from a bunch of other posts on how to find the master code and user code for early-model Excursions:
https://www.ford-trucks.com/forums/1...l#post10496445
Old Nov 4, 2011 | 10:32 AM
TXtinct's Avatar
TXtinct
You'll shoot your eye out
I don't think I'm getting power to my key pad. How is one to determin this? Do they light up when pushed?
Old Nov 4, 2011 | 11:00 AM
gr8scott72's Avatar
gr8scott72
Press the right two buttons at the same time. This should lock all the doors.
Old Nov 4, 2011 | 11:06 AM
TXtinct's Avatar
TXtinct
I will give it a try, thanks.
Old Nov 4, 2011 | 12:13 PM
Ghadaz's Avatar
Ghadaz
I went to the dealer for a diagnostic and replacing a shorted catalytic senseor. Asked them if they could find the code for me. They did and didn't charge me.
Im sure if you go in just for them to pull the codes, they will charge you but if you have them work on the vehicle and ask them if they can get the code for you, they will do it for free.
Old Nov 4, 2011 | 12:28 PM
TXtinct's Avatar
TXtinct
Okay, it worked... Doors locked by pressing the last two buttons. Now to just find the stinking code. I thought I had figured it out by looking behind the dash but the number I found didn't work. I guess I will have to go through the process of manually doing it.
ldunston7621
Apr 24, 2015 11:00 AM
tjblair
Jan 5, 2012 04:17 PM
cabldawg
Nov 5, 2011 08:59 PM
chicagodragon
20
Sep 16, 2011 01:48 PM
fordmanss12
1997 - 2003 F150
Jul 19, 2005 10:49 PM
