Front bump stops
Old Oct 25, 2010 | 10:17 AM
luxury's Avatar
luxury
Front bump stops
I need new front bump stops for my 2003 4X4. I see some folks here use Energy Suspension. When I look online, they all have a single attachment bolt, but my stock bump stops have 2 bolts (forward and aft of the bumper). Are the energy suspension bumps stops really a direct replacement? Is there a hole under the stock mounting plate (doesn't feel like it, but I haven't pulled the old mounting plates yet) or do the ES bump stops use one of the factory bolt locations?
Old Oct 25, 2010 | 11:49 AM
indyF-350psd's Avatar
indyF-350psd
you can't fix stupid!
i went throough the same thing you are and ended up getting the newer style squarish bump stops. i think its 03 and newer they started putting the square ones on anyway.......
Old Oct 25, 2010 | 12:43 PM
EXCURSIONATOR1's Avatar
EXCURSIONATOR1
The ones in your pic will work. I used urethane traction bar snubbers on mine.
Old Nov 1, 2010 | 08:56 AM
luxury's Avatar
luxury
Thanks for the input. I ended up getting a slightly different Energy Suspension model (in black). They are smaller than the OEM stops, but made from a harder material. The OEM stops have a mounting plate and 2 bolts, but there is a hole in the frame between the OEM mounting bolt holes, so any stop with a single bolt will work. The stop bolt just barely cleared a bolt that runs horizontally through the frame.
Old Oct 13, 2011 | 05:19 PM
st8yd's Avatar
st8yd
So how are these holding up?
Old Nov 4, 2011 | 01:04 PM
luxury's Avatar
luxury
Still in good shape after a year.
Old Nov 4, 2011 | 02:22 PM
st8yd's Avatar
st8yd
Thanks, I went ahead with them a couple wks ago.
Old Nov 4, 2011 | 04:56 PM
hasteranger's Avatar
hasteranger
I need new ones too, my factorys are literally gone.
97F250_HD
May 16, 2017 07:52 AM
Danj2718
May 12, 2017 05:52 PM
tjmike
Nov 10, 2015 05:41 PM
HiZ
Apr 3, 2013 08:54 PM
datchew
16
Mar 18, 2005 01:54 PM
