Trans shudder
Old Nov 3, 2011 | 12:24 PM
johngeorge's Avatar
johngeorge
Trans shudder
06 with 5.4 and AT. It shudders in overdrive during light to no acceleration. I was told it was the converter. I was also told by a technician in a trans shop that the Trans-X additive for hypoid oil in a posi-trac was ok to use even though the back of the tube says "Not safe for automatic transmissions". Does anyone know if this is accurate or if the guy was just blowing smoke? Thanks
Old Nov 3, 2011 | 03:45 PM
jk080's Avatar
jk080
Transmission Rebuilder
I have used additive for the posi trac differential before and it did work, but I would recommend just changing the fluid first, most of the time that will fix a mild converter shudder.
Old Nov 3, 2011 | 08:03 PM
johngeorge's Avatar
johngeorge
Thank you for your input. I really do appreciate getting info from a tech and not just someone who is repeating what he heard elsewhere but doesn't really know.
Old Nov 4, 2011 | 12:25 AM
DieselBeast01's Avatar
DieselBeast01
x2 on this. I had a pretty bad TC shudder in my 01 7.3 and a fluid and filter change made it go away. Although, the tranny did end up blowing out about a year later. It didn't have anything to do with shudder though.
Old Nov 4, 2011 | 08:32 AM
gunman_sr5's Avatar
gunman_sr5
Trailering
The 2007 I am test driving right now does this as well. I noticed this accelerating from 40. It has me a bit concerned.
Old Nov 4, 2011 | 10:15 AM
johngeorge's Avatar
johngeorge
I would inform the dealer and let them know that it has to be fixed before you consider a purchase.
groggf250
Feb 13, 2010 03:44 PM
sharky
Jul 13, 2009 09:56 PM
Trial and Error
General Automotive Discussion
Dec 15, 2004 02:16 PM
manta523
Aerostar
Sep 18, 2003 04:14 PM
