Clutch spring F2
Old Nov 3, 2011 | 10:08 AM
john fin's Avatar
john fin
Clutch spring F2
Where does the rear(towards tailgate) of the clutch pedal spring hook onto?
Old Nov 3, 2011 | 10:45 AM
jmadsen's Avatar
jmadsen
Google search is amazing< Found this quicker than it took to read your question. I tend to do it too though...
https://www.ford-trucks.com/forums/9...al-spring.html
Sometimes it's just more fun to ask the question hoping someone will just come over to my house and help me hook it up.
Speaking of hooking the spring up to the cross member, it can sometimes be a real pain to get the hook end of spring into the slot its supposed to go into.
good luck
Josh
Old Nov 3, 2011 | 12:00 PM
john fin's Avatar
john fin
spring
The transmission cross member? Seems way too low. I dont understand the pics on that other link. I will print it out and match it up.
Old Nov 3, 2011 | 12:07 PM
john fin's Avatar
john fin
pic
To me by looking at that picture it looks like it hooks into the bottom of the floorboard in the area before it turns up on an angle.
Old Nov 3, 2011 | 03:13 PM
jmadsen's Avatar
jmadsen
there are 2 small holes above your master cylinder mounting bolts. the spring hooks into the one closest to the frame rail. about an inch down from the top of the frame crossmember. If I remember right you kinda have to twist and turn your spring end just so to get it in.
Old Nov 3, 2011 | 04:38 PM
4tl8ford's Avatar
4tl8ford
The Loop at the tip of the pencil is a large cotter pin that goes thru the hole and is spread on the back side of the crossmember
Old Nov 3, 2011 | 04:56 PM
jmadsen's Avatar
jmadsen
Are you saying the spring hooks to the loop of the cotter pin?? That would be easier to hook up for sure, but seems like the couple I've seen just hooked directly into the hole on crossmember.
Old Nov 4, 2011 | 07:41 AM
john fin's Avatar
john fin
pic
Thanks for the pic Dick, I saw the hole, didnt know what it was for until now.
woodhd
27
Nov 25, 2024 02:53 PM
F-250 restorer
Mar 18, 2018 01:24 PM
rangerottis
Oct 18, 2014 08:19 PM
dspeer75
May 5, 2009 08:04 PM
nmarlowe
May 20, 2004 08:10 AM
