Sponsored by: Auxito
Hard starting
Old Nov 3, 2011 | 07:06 AM
00GT's Avatar
00GT
Hard starting
F150 4.6 its been starting just fine until yesterday. It sounded like the battery was weak. So I replaced it with no change. Now I'm thinking the startor.
Any thoughts?
Old Nov 3, 2011 | 08:25 AM
steve(ill)'s Avatar
steve(ill)
slow cranking ? Yes normally battery or worn starter.... or bad battery cables, corroded ground cable, etc.
Old Nov 3, 2011 | 08:50 AM
00GT's Avatar
00GT
Yes exactly. slow cranking. I cleaned the cables. The starter is not making any abnormal noise just sounds like its laboring
Old Nov 3, 2011 | 12:42 PM
00GT's Avatar
00GT
Well starter is dead! All I'm getting is click-click-click nothing.... And my truck is sitting in the parking lot at work. This should be fun.
Old Nov 3, 2011 | 03:36 PM
KingRanchMan02's Avatar
KingRanchMan02
Don't assume that the starter is the problem. Use a voltmeter to verify that the starter is getting the needed voltage. The heavy cable from battery to starter should of course have 12 volts DC at the starter. There is a much smaller wire that comes front the starter solenoid that has voltage applied when the key is in the start position. No voltage there otherwise. Good luck!
Old Nov 3, 2011 | 05:47 PM
00GT's Avatar
00GT
Got the new starter put on and it starts better then it ever did before.
But when I had the starter off I found a problem.....broken manifold bolt! My next project.
Old Nov 4, 2011 | 07:20 AM
KingRanchMan02
Got to love finding new projects in the process of fixing something else!
Troy conrad
Jun 23, 2019 11:09 PM
River19
13
Sep 9, 2014 02:55 PM
joekacker
Nov 9, 2012 08:03 AM
Lead Head
1983 - 2012 Ranger & B-Series
17
Sep 19, 2007 10:19 PM
BK0013
Jun 4, 2007 07:37 PM
