IPR removal help
Old Nov 3, 2011 | 12:21 AM
01PS's Avatar
01PS
IPR removal help
So...... I sure picked the wrong damned time to quit smoking. There's an oil line or something in the way of me getting my socket over the IPR. I'm afraid of breaking it or me if I keep trying to force the socket on. Any tips? Thanks!
Old Nov 3, 2011 | 12:51 AM
01PS's Avatar
01PS
Geez.......everyone went to bed early tonight I guess.
Old Nov 3, 2011 | 01:09 AM
01PS's Avatar
01PS
Nevermind, it seems that of the 3 1/2" drive, 6 point, deep well, 1-1/8" sockets I have (including Lowes brand Cobalt mentioned in one of the writeups) has a hole big enough for the end of the IPR. I can't slide the socket on deep enough to enagage the "nut" part of the IPR.
Old Nov 3, 2011 | 01:18 AM
hotroddsl's Avatar
hotroddsl
Mike you'll have too either get a snap-on deep well and drillout the center or cut and welt 2 other sockets together I've had some luck with a snap-on and a crafts man end wrench used to get a 1/16 of a turn then change wrench anne repeat but that takes forever! Good luck
Jim & fat Monty
Old Nov 3, 2011 | 01:39 AM
01PS's Avatar
01PS
Wow, what a PITA compared to the writeup I got. Is there an alternative?
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
Slide the socket on first, without the ratchet, then you can get just enough of the ratchet in the socket to turn it. It will not go all the way in the socket but it doen't need too. That is how I got mine out several times.
Good luck.
Old Nov 3, 2011 | 01:43 AM
01PS's Avatar
01PS
Good luck.
The hole in the center of my sockets is not big enough for the end of the IPR to go through. I can get a ratchet on no problem, because I need the socket to go another 1/4" or so on the IPR before I can catch the "nut".
Old Nov 3, 2011 | 06:28 AM
brownie83's Avatar
brownie83
i just did mine friday...used a plumbers socket from lowes. actually bought the whole kit. it is a 1 and 5/32 plumber's socket...
here is the link...Shop Superior Tool 6-Piece Premium Shower Valve Socket Wrench Set at Lowes.com
good luck
Old Nov 3, 2011 | 08:38 AM
Franko72's Avatar
Franko72
Molon Labe
good luck
X2^^^^
I use the same sockets as Chris, works beautiful.
Old Mar 14, 2012 | 10:02 PM
Spool&Go's Avatar
Spool&Go
Back up and running after a $286 IPR and a $20 1-1/8" deep socket. I am definitely going to take that brand new IPR out when we attack that HPOP bolt. Ugh... would have ordered one but needed my truck..... Im trying to justify it with peace of mind.
Once I get the bolt ground off and that stock HPOP out, I'll just get the IPR mounted up on my new T-500 and throw it in all at once.
Any tricks to getting those oil lines off without a tool? or should I just order one up so that its not a hassle come time to take them off.
Old Mar 14, 2012 | 10:07 PM
JT250's Avatar
JT250
Clay sent one with my hpop. I have done it w and w out the tool. With is waaaaaaaay easier.
Old Mar 14, 2012 | 10:10 PM
BigAlsPSD's Avatar
BigAlsPSD
You'll probably get a tool, another thing that works well is the little pry bar for removing push in fasteners.
Old Mar 15, 2012 | 05:07 AM
Franko72's Avatar
Franko72
Molon Labe
Bryce, I would just order the tool from Clay, you've been thru enough headaches with your hpop. The tool makes an otherwise frustrating job simple, and it's only around $16.
I wish you the best getting that bolt out.
I guess I got lucky, I tossed my T500 on my truck just before an 880 mile trip pulling the camper. Everything came apart and went back together just as planned. (very unusual for me )
Old Mar 15, 2012 | 03:50 PM
AllaboutMPG's Avatar
AllaboutMPG
anyone here try this?
6.0 7.3 Powerstroke Fuel Oil Line Release Tool - YouTube
LeoJr
Nov 14, 2013 08:15 PM
Franko72
60
Jan 31, 2011 02:43 PM
viperbluelx
Jul 8, 2007 04:54 PM
Hangfire
Garage & Workshop
Jul 25, 2005 11:17 AM
1stoldtruck
Garage & Workshop
Aug 30, 2003 02:57 PM
