trans shift kit
Old Apr 1, 2005 | 06:50 PM
dozer384's Avatar
dozer384
trans shift kit
has anyone installed a trans shift kit into a 4r100 trans? if so which brand did you use? did the shift kit get rid of those sloppy shifts? and can you use the sonnex tricumulator valve with a shift kit? if i install just the tricumulator valve will it eliminate the sloppy shifts?
Old Apr 1, 2005 | 09:53 PM
bigdaddyTank's Avatar
bigdaddyTank
Sonnax/Tricumulator kit is what you want. I just installed mine today, I just came in from cleaning up. Its the best $50 you can spend! I should have done this first. The shifts are firm, they dont bang and its huge difference from the slipping into gear. I got mine from blackclouddiesel.com $50 with shipping. Its pretty easy to do also.
