help me please!!!
Old Nov 2, 2011 | 10:02 AM
Kemicalburns's Avatar
Kemicalburns
have you changed the transmission fluid? have you taken it out onto the hwy and really driven it good and hard for a bit. I would run some Delo 15w40 diesal grade oil for the first 3000miles to really clean up the inside of the motor. then move over to a 10w40 or 10w30.
the cat converter may also be partially clogged, unhooking the Y pipe and driving around briefly to see if it peps up a bit.
Old Nov 2, 2011 | 04:57 PM
stephens220's Avatar
stephens220
it is not the stock carb. i am goin to yank off the converter either tonight or the next mighty cold in oklahoma today. also im goin to barrow my buddy compression checking apperatisiser. if all is good there i guess ill have to spring for a new carb any ideas on what i should get? im thinking edlebrock 600
Old Nov 3, 2011 | 11:28 AM
bradb2230's Avatar
bradb2230
Edelbrocks are good carbs for ease of use. Though I have a Holley 650 on my 390. I chose Holley for the tunablility, though they are a bot more sensitive to atmospheric conditions, such as temperature, and barometric pressure.
Old Nov 3, 2011 | 12:25 PM
stephens220
ease of use is what i am lookin for. im so tired of messing with this p.o.s holley i just got done changeing the coil and that helped but it still doesnt seem to have all the power that it should. im werkin all night so i will check the compression tomarrow morning before i go to werk again. the converter is already gone so i know that that is not the issue
Old Nov 6, 2011 | 07:04 PM
stephens220
well i got my compression check and everything is good 110 or better. i also just baught an edlebrock 600 carb with manual choke. any pointers or tips to hook this 300 dollar bill up and get to slinging some mud
73driver
Jun 19, 2014 08:07 PM
8525ford
May 4, 2010 04:43 AM
abob
Nov 3, 2009 08:03 PM
AustroTom
Jul 9, 2009 09:23 AM
jsmahan
17
Feb 11, 2008 07:10 PM
