Mine looks exactly like your pic! But I've also got a two wire plug it's just setting right next to the frame with a factory dust plug in it!?!?!
Just checked there's one on the other side as well! It's snapped into a hole on the frame, the left side one probably did too!i must have moved it when I installed the x-mission! Inn look for courtesy lighting volts tomorrow
Jim & fat Monty
