Another "What is it?" question
Old Nov 1, 2011 | 03:06 PM
BillyBob69's Avatar
BillyBob69
Snooping around under my truck the other day to make sure all is good to go since we have a couple of storms coming..and I noticed this 2 wire "harness" behind the left/front wheel well.
Any thoughts on what it "should" go to?
99 F350 Lariat. Auto trans.
Possibly a feature I could add? (Always room for more truck "toys")
Thanks all!
Old Nov 1, 2011 | 03:07 PM
mueckster's Avatar
mueckster
ABS sensor wiring for those trucks equipped with 4 wheel ABS. Should have one on both sides.
Old Nov 1, 2011 | 03:10 PM
BillyBob69's Avatar
BillyBob69
WOW...That was fast. I hardly had to to refresh the page.
So... no new pre-wired toys. Oh well.
Old Nov 1, 2011 | 07:38 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
I have that to. Mines by the battery. Driverside. On my 01 excursion and e99 sc. Diagnostic port?
Old Nov 1, 2011 | 11:05 PM
hotroddsl's Avatar
hotroddsl
My '02 has one with a factory plug installed on it an it's separate from my ABS wires! Schematics anyone
Jim & fat Monty
Old Nov 1, 2011 | 11:12 PM
BigAlsPSD's Avatar
BigAlsPSD
The only other possibility wiring wise in that location I would think would be running board lights. But the OP's pic looks like my ABS sensor location on my 2000.
Old Nov 1, 2011 | 11:16 PM
hotroddsl's Avatar
hotroddsl
Running board lights.....hmmmmmmm! I've got ABS, there hooked up, I'm gonna check that for power with the light switch! I have wonderd what it was for years but never checked..
Jim & fat Monty
Old Nov 1, 2011 | 11:23 PM
BillyBob69's Avatar
BillyBob69
Oooohhhhhh. Side lights. I kinda like that idea.
Hotroddsl.... let us know what you find out. Also check when you open the door. Could be for when you get in and out.
Old Nov 1, 2011 | 11:24 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I have that plug, and its plugged in. My friends 2001 V10 has it and its unplugged. Dunno what it does to..
Old Nov 1, 2011 | 11:32 PM
hotroddsl's Avatar
hotroddsl
Spooner what's it plugged into?
Old Nov 1, 2011 | 11:34 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
You want me to go and look? Grrr ok hold on
Old Nov 1, 2011 | 11:36 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Its the ABS sensor on the hub. Looks like your ABS is not hooked up Jim.
Old Nov 2, 2011 | 12:02 AM
hotroddsl's Avatar
hotroddsl
Hmmmmmmm... That's not it! Mine is definitely not the abs ?!?!?!
Old Nov 2, 2011 | 12:03 AM
BigAlsPSD's Avatar
BigAlsPSD
Where does your ABS wheel speed sensors plug into?
Old Nov 2, 2011 | 12:04 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Well find out where your ABS sensor goes to then let us know.
