Turbocharging
Old Nov 7, 2011 | 08:26 PM
Nicknaz's Avatar
Nicknaz
Great thanks I was just wondering about it. Just had a new injector pump a month ago runs great now, thinking of changing out the injectors now
Old Nov 7, 2011 | 08:28 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
Originally Posted by 91dirtydiesel
If you went to a JY you'd more than likely find a 93-94 idi with factory turbo somewhere (maybe). If it hasn't been picked apart then you be good to go.
there is a 7.3L IDI factory ats 093 at a junkyard about 10 miles from me in a slantnose f250. he will only sell the truck as a hole though since it runs.
Old Nov 7, 2011 | 08:33 PM
91dirtydiesel's Avatar
91dirtydiesel
Check market place here
7DF250's Avatar
7DF250
I have a 1994 factory turbo IDI, considering selling the turbo stuff and getting the banks or hypermax kit, or can I work with what I have already?
Old Nov 7, 2011 | 08:36 PM
91dirtydiesel
Y? Ats works great if you make it
Old Nov 7, 2011 | 09:05 PM
akamacgyver's Avatar
akamacgyver
Clueless spectator!
Turbo and mileage.
I also swapped out a NA IDI with 190k mi on it and bolted up my Sidewinder to it, 35 thousand miles later now and she purrs. Just dont get greedy and go turning up your boost. keep it around 10 and you should be fine. If you want to crank up the boost do some reading about stronger head bolts and turning up fuel and other related issues. Also get at least a pyrometer so you can monitor EGT's with any turbo install.
Good luck,
Mac.
Old Nov 7, 2011 | 09:11 PM
91dirtydiesel
I agree, get gauges and keep it in moderation...although, I recently plugged the turbo on the market place and it hit 15 just about every time I drove it, probably only about 1000 miles but I had to back out off throttle on freeway hills just so I didn't pass 15psi. idk how long it would have held up but for the time being it was just fine. Gauges are a bit part of getting performace out of these, EGTs is most important IMO
Old Nov 7, 2011 | 11:41 PM
typefour's Avatar
typefour
I do mods to the stock and ats turbos to perk them up some.
Pm me if interested.
Old Nov 8, 2011 | 10:53 PM
7DF250's Avatar
7DF250
I'll keep you in mind thanks
CannonBryan
Feb 22, 2016 07:19 AM
RA31925
Jul 13, 2013 03:51 PM
blazinjames
Dec 8, 2011 04:11 PM
leonardpre7.3
General Diesel Discussion
17
Nov 24, 2008 08:39 AM
patriottow
Oct 7, 2005 07:40 AM
