1977 Ford Steering column question.
Old Oct 30, 2011 | 08:22 PM
1977FordManiac's Avatar
1977FordManiac
Hello all,
This is my first time here so please make fun of me if do something dumb! I have a 1977 F150 SWB 4x4 that had a manual transmission in it. I also have a 1978 F250 extended cab LWB 2wd with an automatic transmission that I am using for parts. I am going to put a C6 automatic transmission into the SWB 77' Ford. I want to change out the steering column so that it has tilt and a shifter. I thought this would be a simple swab, but was wrong. The steering column out of the 78' Ford is too short. My question is did Ford make a steering column for a 4x4 with an automatic transmission that would be long enough to work?
Old Oct 30, 2011 | 09:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You need to find another 4X4 with tilt and auto. As you found out, the 2WD columns are too short to work on the 4WD.
Old Oct 30, 2011 | 11:29 PM
hasteranger's Avatar
hasteranger
yep. and the tilt columns are sorta rare in the trucks. Try searching for a bronco, it seems like a lot of them had tilt, 4wd, and auto, at least around here.
Old Oct 31, 2011 | 07:31 PM
1977FordManiac
Awesome. Thanks for the reply guys!
Old Nov 1, 2011 | 12:25 PM
1977FordManiac
Back again. Does anyone know what steering columns would be compatabile with the 1977 Ford F150. I am having trouble finding one at the salvage. Would one out of a bronco work?
Old Nov 1, 2011 | 01:43 PM
Mexican77's Avatar
Mexican77
WELL IF IT´S COMING OUT OF A BRONCO GOTTA BE 78 OR A 79.
Old Nov 1, 2011 | 04:02 PM
kelsey_kaye's Avatar
kelsey_kaye
Why are you yelling?
I thought this was what the guys above were telling you to search for.
Old Nov 1, 2011 | 06:21 PM
bassman755's Avatar
bassman755
ebay has had some for a ok price
Old Nov 1, 2011 | 07:43 PM
hasteranger
Yeah 78/79 bronco or 73-79 ford truck. earlier/later may work but probably won't.
BiltFordTuff
Jul 11, 2011 09:39 PM
pitbulls20
Mar 2, 2008 01:25 PM
Flatbed392
Jan 30, 2006 07:47 PM
bpt7018
Jul 24, 2003 09:24 AM
Stoney
Nov 27, 1999 05:42 PM
