Spiking Idle...?
Old Oct 30, 2011 | 02:25 PM
Diesel 724's Avatar
Diesel 724
Spiking Idle...?
When im idleing my rpms will begin to jump up and down even when im driving at low speeds which tends to give you whiplash! RPMs go up my and truck jumps forward! I have no idea whats going on, when im driving at higher speeds it still does it but not nearly as bad. Oh and it has done this before, quit doing it and months later will do it again!
Old Oct 30, 2011 | 02:35 PM
woodnthings's Avatar
woodnthings
It could be throttle pedal related. The throttle is controlled by a potentionometer and if yours is acting up it could cause that. The other thing to look at is the ICP sensor. Make sure there is no oil in the connection. Oil causes the signal to get fouled up and that can cause the throttle to be inconsistant.
Old Oct 30, 2011 | 10:07 PM
Diesel 724's Avatar
Diesel 724
Today my SES light flashed but didnt stay on. Maybe its related. Can Advance Auto check a code if the light went off?
Old Oct 30, 2011 | 10:14 PM
twags6's Avatar
twags6
Probably not. Most of the codes are manufacturer specific, and require a good scanner to pull. A repair shop would be the place to go, or if someone near you has an AE scanner, they can pull them for you. Last resort is your local dealer.
Old Oct 30, 2011 | 10:31 PM
MR5x5's Avatar
MR5x5
Unplug your ICP and see if the problem remains. Perfectly ok to drive the truck with the ICP unplugged.
Old Oct 31, 2011 | 11:00 AM
Diesel 724's Avatar
Diesel 724
Where is my ICP located exactly?
Old Oct 31, 2011 | 11:38 AM
MR5x5's Avatar
MR5x5
Behind the alternator, front of the drivers side head, on top. Two pin connector. The only connector in the area...
Old Oct 31, 2011 | 01:17 PM
PaysonPSD's Avatar
PaysonPSD
Right in front of the lifting ring.
Old Nov 1, 2011 | 12:30 PM
Diesel 724's Avatar
Diesel 724
Awesome i unplugged it and it stopped! Only now my SES light stays on.
Old Nov 1, 2011 | 02:08 PM
MR5x5's Avatar
MR5x5
Sounds like you are 99% there. You need a new sensor. The light will stay on with the sensor unplugged. Like said before, you can drive the vehicle without doing any damage with the sensor unplugged. You just won't get optimal fueling. Sensors range from about $55 to $150 depending on where you go. Check e-bay if you trust them...just look for good seller reviews.
Old Nov 1, 2011 | 06:49 PM
woodnthings
Here is what you need. Much cheaper than your local dealer.
Riffraff Diesel OEM ICP Sensor
Trevor Whitten
Mar 21, 2019 05:29 PM
bryan13
Jun 24, 2008 06:08 PM
jgentle
Dec 20, 2005 09:52 PM
fordman102
Dec 4, 2003 08:42 AM
Mary_Kate_Olsen
1978 - 1996 Big Bronco
Oct 5, 2003 10:29 PM
