2005 6.0 eats batteries
Old Oct 30, 2011 | 10:12 AM
SDpackman's Avatar
SDpackman
I have a 2005 F350 with a 6.0. I can't get a set of batteries to last much over a year. I have tried several different brands and even tried dry cells without any luck. The engine cranks a long time before starting. Doesn't matter if it's cold or warm. I have a hunch the two are connected. My local mechanics can't find anything wrong, tried reflashing and had no luck. Has anyone else had this problem? If so, what did you do to correct it?
Old Oct 30, 2011 | 11:02 AM
npccpartsman's Avatar
npccpartsman
There is a tech folder at the beginning of the 6.0 forum with a hard start/ no start thread in it that you should read.
Read this thread about parasitic battery drain: https://www.ford-trucks.com/forums/1...ery-drain.html and how to test for it.
As for the long crank to start: check ICP and IPR values. See if you can check to see how many RPM's your starter cranks your motor. Test your FICM voltage. What CCA batteries are you using? What oil and filter are you using--these can be critical?
mgb50
Nov 1, 2012 07:43 PM
Kevin L Phelan
Sep 18, 2012 05:48 AM
bigmacmonday
Apr 23, 2012 07:09 PM
bad466
Oct 8, 2010 09:19 PM
chrism88
Aug 15, 2009 04:58 PM
