2005 6.0 died while driving help!
Old Apr 23, 2012 | 04:45 PM
bigmacmonday's Avatar
bigmacmonday
Hey guys, my 2005 6.0 powerstroke just randomly and instantly died while i was driving 45 mph. Would crank but not start. I let it cool off and tried it again, but still no start. Towed it to the local mechanic and he said there is no oil getting to the HPOP but is unsure what is wrong with it. Any ideas? Thanks in advance for the help.
Old Apr 23, 2012 | 05:18 PM
greentree ford's Avatar
greentree ford
2005 i would check stc fitting first thing
Old Apr 23, 2012 | 05:30 PM
texans's Avatar
texans
Need to air test the hpo sysytem. STC would be highly suspected.
Old Apr 23, 2012 | 05:37 PM
bigmacmonday
What would be the best way to test this?
Old Apr 23, 2012 | 05:43 PM
bigmacmonday
If I understood the mechanic correctly i believe he said the oil wasnt getting to the hpop. Could it still be this fitting?
Old Apr 23, 2012 | 06:10 PM
ul37's Avatar
ul37
bigmacmonday
send you a pm for high pressure oil system air test.
joe
Old Apr 23, 2012 | 06:23 PM
texans's Avatar
texans
How does he know that there is no oil getting to the HPOP? I'm betting he's saying that it's not building high pressure oil. If indeed there is no oil going to the HPOP (witch it is feed by reservior under the oil cooler) then you have a problem with the low pressure oil system. The LPO pump feeds the reservior for the HPOP.
Old Apr 23, 2012 | 06:58 PM
bigmacmonday
I'm not sure how he knew there was no oil getting to the hpop, and I tried to call him and find out and can't get an answer or a call back. But all he said was the it was getting absolutely no oil pressure and that he was just going to have to tear into it from the oil pan up. . But I will find out exactly what he did as soon as I can. If it was the STC fitting which I had hoped it was, I was going to try and do the job myself. Now I have no clue what to do and am afraid neither does my mechanic. . .
Old Apr 23, 2012 | 07:07 PM
texans's Avatar
texans
Not getting oil pressure doesn't mean not getting oil. And he is talking about the HPO system correct? If so, and he says he needs to remove oil pan to investigate, then you need to get that truck back ASAP, and never take it back there again. Sounds like this guy doesn't know squat about a 6.0
Old Apr 23, 2012 | 07:09 PM
ul37's Avatar
ul37
2nd that. get your truck back.
Mr_CarMan007
May 19, 2016 04:03 PM
bad466
Oct 8, 2010 09:19 PM
chrism88
Aug 15, 2009 04:58 PM
gman1962
Sep 26, 2005 03:23 PM
