Christmas is right around the corner and I will be asking for better speakers in my truck. Any suggestions on which will fit/ sound the best without having to install an extra amp?
Should be 6x8 speakers if Ford hasn't changed them. The 4 way Pioneer speakers from Walmart sound pretty good.
Your best bet to see what fits for sure is to look up your truck at Crutchfield: Car Stereo, Speakers, Home Theater, LCD TV, Digital Cameras.
They usually include wiring adapters as well.
What are you willing to spend? Alpine makes a good mid level 2 channel speaker for around $100 a pair. If you really want to spend some coin then you need to check out the offerings from JL Audio.
Of course the only real way to get better sound is an amp or headunit upgrade. The factory headunit has some limitations that an aftermarket unit wont. I would suggest a mid priced 4 channel amp and a mid priced set of speakers.
