Sponsored by: Auxito
Fuel Pressure
Old Oct 28, 2011 | 04:27 PM
Neo1's Avatar
Neo1
Fuel Pressure
My Ford is 2001 F150 4.6L V8.
One thing I noted while cleaning the injectors; I read that the fuel rails (schrader valve) needed to be depressurized. I was expecting a geyser from what I'd read, but it was a nonevent.
Is this normal? Does it bleed off if you wait for the engine to cool down?
Old Oct 28, 2011 | 05:13 PM
enriched&beyound's Avatar
enriched&beyound
pressure should be some where near 30-35 psi. and if it is correct then , yes, a geyser of some sort should be present.
If you depressed this valve long after running this, or turning the key to the on position, ( like 4-8 hrs) then you might get a "non-event".
You might want to get the fuel pressure tested to be an the safe side.
troy676
1983 - 2012 Ranger & B-Series
Dec 13, 2013 09:50 AM
rv8riveter
Modular V8 (4.6L, 5.4L)
Aug 7, 2011 12:33 AM
sharky
Jun 19, 2006 07:27 PM
92Custom
Apr 12, 2002 11:06 PM
blueford
Nov 22, 2000 12:41 AM
