Fuel pressure
Old Nov 20, 2000 | 01:50 PM
blueford's Avatar
blueford
Fuel pressure
I have a 1986 F150 302, when I turn the motor off my fuel pressure drops to zero within a few seconds. I pulled all of my spark plugs and none of them are wet with fuel, so I don't have injectors that are leaking. Is there a check valve in the system to maintain pressure or is the fuel pump supposed to keep the pressure.
Old Nov 21, 2000 | 06:26 AM
DannyP's Avatar
DannyP
Fuel pressure
Old Nov 22, 2000 | 12:41 AM
Torky's Avatar
Torky
Fuel pressure
The 90's trucks have a check valve built into the fuel pump. Don't know if the 80's had a separate check valve. What happens if you just key on, not start? Does the fuel pressure come up, and after the 1 second has expired and the pump shuts off, does the pressure fall off? If so, you could try crimping off the return line somewhere where its a rubber hose, and try it again. If it holds pressure then, then it may be the pressure regulator leaking some fuel back to the return, like its not sealing tightly.
jbeecham
Jul 2, 2010 07:34 AM
TurnerBioDiesel
Jun 21, 2010 02:09 PM
ms1780
Jun 22, 2009 04:36 PM
scorpiox31
Dec 8, 2006 08:52 PM
GILL353
Bronco II
Dec 4, 2003 05:29 PM
