Bullydog chip
Old Oct 28, 2011 | 12:12 PM
ssmith622's Avatar
ssmith622
Bullydog chip
I put a Bullydog chip in my truck years ago it seemed two run great. After I broke the transmission I pulled the chip out before I took it to the transmission shop. After they put the new transmission in I reinstalled the chip. It was quite some time before I decided to use the highest setting and get on it. It just wasn't running the same and my gas mileage was considerably worse. After cleaning and replacing sensors trying to figure out what the problem was I finally decided to get a dp tuner. It turns out that it was the Bullydog tuner making my truck run bad. Is it possible that it was installed improperly causing the truck to run bad? Or did the chip itself go bad?
Old Oct 28, 2011 | 02:32 PM
riverrat41's Avatar
riverrat41
First off you made the right decision to get the DP Tuner and get away from the BD...Yes,we have seen several different programmers go bad and cause all kinds of problems with the 7.3's.
If you have trouble with the DP(I bet you won't)then a phone call to Jody and he will fix ya up.
Old Oct 28, 2011 | 07:11 PM
diesel-fitter-bum01's Avatar
diesel-fitter-bum01
Well if your putting "GAS" in it,it will run bad. HAHA kidding. Guess I have never heard of canned tunes going bad,but anything can happen when installing new parts.
bigbubba87
Jun 9, 2011 08:05 AM
F450 Aaron
Jun 15, 2007 10:21 PM
Rich in CO
Mar 6, 2006 10:59 PM
the1mg
30
Jan 30, 2006 06:12 PM
oclawdog
Computer Chips & Tuners
Nov 22, 2005 01:58 PM
