2000 7.3 will not start
Old Oct 28, 2011 | 09:57 PM
let_the_coal_roll's Avatar
let_the_coal_roll
Originally Posted by BigAlsPSD
To properly diagnose what is going on, it would be very helpful to be able to view live data with a scan tool. But back to the basics.
Do you get a Wait to start light when the key is on?
If you have the filter bowl drain open and the key is turned on does fuel pour out of the drain?
Is there more than 1/4 tank of fuel?
Is the Tin nut on the back of the IPR?
When it died did you get a Service Engine Soon light?
The wait to start light does come on, it is getting fuel to the fuel bowl, the tin nut was on the back of the ipr, it has half a tank, and it does not have a service engine soon light on.
Old Nov 4, 2011 | 04:11 PM
let_the_coal_roll
So i was talking to a local diesel mechanic that said it sounds like the injector drive module. Is there any way to test this??
Old Nov 5, 2011 | 11:39 PM
BigAlsPSD's Avatar
BigAlsPSD
The way to test the IDM would be with a BUZZ test, and checking codes. Maybe your diesel mechanic friend has a capable scanner and could pull the codes for you?
You can also test all of the wiring if you suspect IDM or injector issues too.
GB_Tech_Bulletin_103_Ford IDM_Module_Replacement (1).pdf
Old Nov 6, 2011 | 10:40 AM
GT6's Avatar
GT6
More resistance values needed.
Hello, New to FTE.
2000 F-250 Power Stroke
Manual Tranny
Everything stock
170K miles.
I've been chasing white smoke starts for a year or so. Two different Ford service centers visited. Two glow plug relays installed. This last time they said it needed a new IDM. I took it home when they said $1200 and 3 hours of labor. Got an IDM from Norther Auto Parts and it was a GB reman unit. Installed it and no change. I did perform the tests recommended in the GB tech bulletin at the IDM plug. Everything was good except cylinders 5 and 7 read about 6 ohms. From reading tons of other posts on this site, I've got some good resistance numbers for glow plugs at the valve cover gasket but haven't found anything for injector resistance as measured at the valve cover gasket receptacle. I'd like these numbers to try and rule out the wiring between the IDM and the valve cover gasket.
I'm tired of the dealer replacing stuff and nothing changing with the operation of the truck. I get 10 or 20 seconds of white billowing smoke whenever ambient air is below 50F and engine is cold.
Thanks for your help!
Old Nov 6, 2011 | 10:51 AM
nlemerise's Avatar
nlemerise
Originally Posted by GT6
Hello, New to FTE.
Manual Tranny
Everything stock
170K miles.
Welcome to FTE!
Why not start a thread with your problem, rather than bugger this one up with multiple problems? After a while, everyone will be confused as to the problem being addressed.
Old Nov 6, 2011 | 10:58 AM
GT6's Avatar
GT6
Put it here because of the previous posts reference to the aforementioned GB tech bulletin.
Could be similar problems and fixes to the original post and therefore didn't think any "buggering" would occur.
Old Nov 6, 2011 | 11:21 AM
BigAlsPSD's Avatar
BigAlsPSD
Hello, New to FTE.
Manual Tranny
Everything stock
170K miles.
You asked for resistance values at the UVCH, should be less than 5.0 Ohms, here is a great writeup on the UVCH/50 cent mod UVCH/50cent Mod. White smoke at startup with known good working GP system, I would start thinking injector orings as a possibility.
Old Nov 7, 2011 | 10:33 PM
GT6's Avatar
GT6
Checked out the post you referenced. That was exactly what I needed to know. Thank you very much!
So, this is one for the wall of shame. I asked the service tech at the dealer 2 times if he was sure all of the glow plugs were working after they replaced the GPR. He of course said yes. Well, I pulled the UVCH plug yesterday and measured resistance on all pins. Guess what, 3 completely open glow plugs!
I'm dumbfounded by the incompetence or the straight up lying.
Should I have believed them about the IDM being bad?
Get to change my first set of glow plugs soon.
Old Nov 7, 2011 | 10:39 PM
BigAlsPSD's Avatar
BigAlsPSD
If you recently had your IDM replaced by them and now you are saying you have 3 open GP's, which wouldn't happen to be on the same side would they? It sounds like you at least need to get under the VC's and have a look at the harnesses. Good luck, GP's are easy, it's getting to them that is the worst part, still not that bad.
Old Nov 7, 2011 | 10:51 PM
GT6's Avatar
GT6
I just use the dealer for diagnosis because I don't have the full blown scanner and frankly because I am brand new to working on diesels. I did the IDM replacement after they said it was bad. Hope they were right.
No, One gone in left bank and two in the right bank. Lucky me. Everything else including injectors ohmed out fine.
I've read enough on FTE to feel fine doing the the plug change thanks to everyone's helpful posts.
Old Nov 27, 2011 | 08:38 AM
let_the_coal_roll
Turns out the IDM was bad. Replaced the part and its running better then it ever has. Thanks everyone for all the help.
Landscape Doctor
29
Oct 23, 2017 06:40 AM
donmi
Jul 26, 2015 08:33 PM
Stang351c
Apr 10, 2013 08:38 PM
justblowin'smoke
Mar 15, 2013 08:52 PM
LoyBaird
Jul 23, 2012 10:14 AM
