Balljoints?
Old Oct 30, 2011 | 02:30 PM
JoSHN's Avatar
JoSHN
Originally Posted by Ted928
I was told that my lower ball joints are going bad. How can I check??
Lift the truck up and place it on jack stands. Look for any cuts or tears in the rubber seal. If you do have a big cut or tear, I would suggest to replace them just to prevent the failure. Sometimes a smaller cut or tear can get a little patch to prevent dirt and grime from entering under the seal.
To check the uppers, grab the upper control arm (UCA) near the balljoint and attempt to move the arm up and down. Look for any movement between the UCA and the steering knuckle.
To check the lowers, grab your tire on the top and bottom and try move the wheel up and down. Look for movement between the LCA and the steering knuckle. Again, you don't want to see any movement on the ball joint.
I find what works fairly easy to check the uppers and lowers though, is to grab one side of the tire (top or bottom) and try to push and pull the tire while looking for movement. I managed to notice that my uppers needed replacing just by rocking the top of the tire while the truck was on the ground.
Also, shake the wheel left and right to look for play on your tie rod ends while you're in there.
Old Oct 30, 2011 | 03:10 PM
Ted928's Avatar
Ted928
Can I check while the suspension is drooped (I have a car lift so I lift using the frame)?Thanks.
Old Oct 30, 2011 | 06:21 PM
Greg B's Avatar
Greg B
Should be able to. I lift the tire slightky off the ground and use a 2x6 and longer pry bar to move tne tire up and down to check for wear. If either upper or lower control arm moves without movement from knuckle, it's time for replacement.
Old Nov 1, 2011 | 01:32 PM
1Aauto's Avatar
1Aauto
Former Vendor
Here's a link to the ball joints section on our website, if you would like to check them out.
2008 F150 Ball Joints
BruceJeremy
1997 - 2003 F150
Jun 12, 2011 08:03 PM
Ranger Louie
2004 - 2008 F150
Jul 31, 2009 09:03 PM
Spotty
1997 - 2003 F150
Oct 3, 2007 09:10 AM
texas4x4
2004 - 2008 F150
May 12, 2007 04:17 PM
eigenvector
1983 - 2012 Ranger & B-Series
Nov 10, 2006 09:05 PM
