Upper Ball Joint Help
Old May 12, 2007 | 07:19 AM
texas4x4's Avatar
texas4x4
Hello all, I am trying to install a leveling kit and having some kind of trouble getting the upper control arm separated. I have tried a ball joint separator only to damage the grease boot and have been beating it with a hammer but to no avail. Here is what I have done. Raised the truck, taken the wheels off, jacked up the lower control arm a little and taken the nut off from the upper control arm. I am afraid I am going to damage something if I keep trying to beat the upper control arm to break it loose.
Is there some kind of retainer or pin I can't see or tell me please what the secret is. I have always been pretty mechanically inclined but I am stumped. Thanks in advance for your help.
Old May 12, 2007 | 07:24 AM
ubereal2's Avatar
ubereal2
On several different light duty Ford trucks, the upper ball joint is not replaceable. You get a complete upper control arm. May have to replace the whole unit.
Old May 12, 2007 | 07:27 AM
texas4x4's Avatar
texas4x4
I forgot to tell yall that my truck is an 2004 F150 4x4 and I am not trying to replace the ball joint, just separate it so I can raise the upper control arm to get it out of the way so I can remove the strut assembly.
Old May 12, 2007 | 07:45 AM
NASSTY's Avatar
NASSTY
Keep whacking it with a hammer,it should come free.
Look > images/8492-12197-171624.jpg
Old May 12, 2007 | 07:53 AM
ubereal2's Avatar
ubereal2
Red face
If you are still hitting it with a good heave hammer. Spray a penetrating oil at the ball joint and steering knuckle area. Hit the steering knucker itself, yes if you use a "pickle Fork" you will tear up the boot on the ball joint.
If you have the lower control arm on a jack. Take off some of the pressure. Place a jack on the crossmember under the engine. And let off on the pressure on the lower control arm. Too much pressure on the lower control arm, and you're just pushing up on something you need to fall down.
Old May 12, 2007 | 08:00 AM
big red c222's Avatar
big red c222
I didn't have to separate the ball joints when I did my kit.
Old May 12, 2007 | 08:04 AM
forcefed86's Avatar
forcefed86
You could also try heating the Steering knuckle. It should break free then.
Old May 12, 2007 | 08:06 AM
big red c222
I thought of heat also, probably melt the rubber.
Old May 12, 2007 | 08:17 AM
forcefed86's Avatar
forcefed86
Yup, dont get the heat source close to the rubber ball joint boot.
Old May 12, 2007 | 09:53 AM
Corey872's Avatar
Corey872
Dont hit the control arm, whack the knuckle a couple of times in the place shown in the photo above. I whacked mine a couple of times with a 3# sledge and it popped right off. The knuckle is cast iron so it's pretty hefty.
Sounds like you were using a 'pickle fork' on your ball joint if you tore the boot? Better get that fixed before you button it up. Water and dirt will sneak in and kill the ball joint in short order
Old May 12, 2007 | 04:17 PM
texas4x4's Avatar
texas4x4
You guys are awesome...I finally got it loose and now I have finished both sides and the 2nd side was definitely quicker. Now all I need is some wheels to finish off the look...Thanks again everyone...
Guest user
Jan 8, 2012 11:30 PM
fenway1702
1983 - 2012 Ranger & B-Series
Nov 5, 2011 08:35 PM
Moto7387
1997 - 2003 F150
Nov 13, 2010 07:28 PM
Hartwa
1997 - 2003 F150
Jan 22, 2007 03:27 PM
