Sponsored by: Auxito
Balljoint Replacement without Control Arm?
Old Jun 9, 2011 | 11:22 AM
BruceJeremy's Avatar
BruceJeremy
Ford F-250, Light Duty, two wheel drive. Balljoints will likely be F-150 size. Is it possible to order the balljoint only, without the control arm?
Cheers,
-Mike
Old Jun 9, 2011 | 12:04 PM
monsterpaint2's Avatar
monsterpaint2
Are you only doing ball joints to save money or is it to save time?
I just replaced ball joints and inner and outer tie rods sway bar bushings and upper control arms on my 2001 F-150 and it only cost $185
I'm sure if you get on ebay you can find the same kit that I bought and get it all done at once.
I dont see why you wouldn't be able to do just the ball joint, if you can beat it out of the control arm
Old Jun 9, 2011 | 12:07 PM
monsterpaint2
SUSPENSION KIT CENTER & DRAG LINK TIE ROD BALL JOINTS | eBay
Looking at this kit I guess you would have to replace just the ball joint and not the control arm, IDK what year your truck is but this kit is for 99-04
Old Jun 9, 2011 | 09:24 PM
BruceJeremy
It's a 1997 and I'm doing the balljoints because the squeaking is getting pretty darn loud! (Why no grease nipples????). My overall goal is to get the truck certified so I can get it plated to use as a work truck. I'm just going to keep going with whatever needs to be done, unless it becomes an expensive farce, that is.
If I get the balljointds replaced, the E-brake fixed and the new box installed, hopefully that'll be all it needs to be road worthy.
Hey, I appreciate your response.
Cheers,
-Mike
Old Jun 10, 2011 | 04:51 AM
blue2golf's Avatar
blue2golf
Cheers,
-Mike
If they're like my '99 F150, you'll have to replace the whole control arm. Ford went cheap and didn't provide grease zerks nor the ability to replace just the upper ball joint by itself. Once you replace the upper control arms with an aftermarket like Moog, however, you will be able to replace the ball joint by itself and it will have a grease zerk for longer lasting performance. (I'm replacing my own uppers this weekend. I've got the Moogs sitting on my workbench right now, along with a set of cam bolts.)
Old Jun 11, 2011 | 04:41 PM
rbeavers's Avatar
rbeavers
No zerk fittings is not a problem. For about 4 bucks at any auto parts store you can buy a needle that fits on the end of your grease gun. Simply slip the needle through the rubber of whatever joint you want to add grease to and pump. Be sure and slowly do it and don't put too much grease into the fitting.
Old Jun 12, 2011 | 08:03 PM
BruceJeremy
Very good! Thank you.
-Mike
corner27
2009 - 2014 F150
Apr 5, 2014 05:44 AM
BruceJeremy
Oct 14, 2010 01:10 PM
rconkl87
2004 - 2008 F150
Mar 31, 2009 08:58 PM
MENESLIS
Dec 30, 2005 10:14 PM
