Sponsored by: Real Truck
Fuel Capacity
Old Oct 25, 2011 | 07:06 PM
Nu2deisel's Avatar
Nu2deisel
Fuel Capacity
I have a 2011 Super Duty Power Stroke. the dealer told me they thought it had a 28 gal tank, but i think I have decided that it has the 24 gal instead. I would really like to have more driving range.
Has anybody done any mods to their truck to add fuel capacity.
The guys at the accessory shop suggested that I put a 30 gal tank in the bed (I have a shell on it) with a gravity feed and a filler on the shell. I'm a little reluctant to cut a hole in the shell, and my experience with this kind op deal is that there will be unforeseen problems with it.
Ideally, I would add a second factory tank with a switch to change tanks, but I would imagine that it would be near impossible to get that done and that it would cost over 2 grand to get it done if it could be done.
If any of you have added fuel capacity I would sure appreciate your input.
Old Oct 25, 2011 | 07:14 PM
powerstroke72's Avatar
powerstroke72
Some of the guys in the 6.7 forum have replaced the factory tank with the Titan 50 gallon on the short bed trucks.
Old Oct 25, 2011 | 07:19 PM
Nu2deisel's Avatar
Nu2deisel
Do you have a link you could share on that?
Old Oct 25, 2011 | 07:23 PM
powerstroke72
Sure.
https://www.ford-trucks.com/forums/1...-bad-news.html
https://www.ford-trucks.com/forums/1...-question.html
https://www.ford-trucks.com/forums/1...ion-video.html
The last link is actually a video of one of our members installing his. There are a lot more threads in the 6.7 on the subject.
Old Oct 26, 2011 | 10:10 AM
smotrs's Avatar
smotrs
Do you stop filling when the pump shuts off or do you continue to fill until the fuel settles at the top of the filler neck? The fact that you suspect a 24 gallon makes me think the former. But without knowing more about your truck, model and wheelbase, it's hard to tell which tank you have.
Here's the information on the brochure,
Fuel tank — 35-gallon capacity (gas engine only)
Fuel tank — 26-gallon capacity (F-250/F-350 137-in., 142-in. and 156-in. WB with diesel engine)
Fuel tank — 37.5-gallon capacity (F-250/F-350 158-in. and 172-in. WB with diesel engine, and F-450)
Old Oct 26, 2011 | 10:24 AM
Nu2deisel's Avatar
Nu2deisel
I guess I have the 26 gal tank then. Yes, I do stop fueling when the pump shuts off because every time I have tried to top it off, it only took another .25 gal or so before it started running over.
Is there a trick to topping it off?
Old Oct 26, 2011 | 11:36 AM
n7bsn's Avatar
n7bsn
On AUX fuel tanks, if you have been reading Rick's issues with the warranty repairs on his 2011 6.7L you will note the message from Ford where one of the items they can use to void the warranty is an AUX fuel tank
Old Oct 26, 2011 | 11:41 AM
smotrs's Avatar
smotrs
Pumping very slowly or in short intervals while watching within the filler neck to avoid it over flowing. That's what I do.
Old Oct 26, 2011 | 12:00 PM
RickBetterley's Avatar
RickBetterley
I know how you feel about these small tanks. 200 miles towing and time to fill up again...and again.
My 2008 short bed crew cab has a 28(?) gallon tank, and that's one big reason why I am taking delivery of a LONG BED 2012 F250 today. 37 gallons.
I find the idea of a big truck with a small tank (and limited headroom - see other threads) more than a little weird.
Old Oct 26, 2011 | 12:19 PM
kmonty2's Avatar
kmonty2
Maybe it's different with your truck but when the pump shuts off on mine I can get almost 3 more gallons in. Just go slow and watch the filler neck, it does go down and it might take 5 min for those last 3 gallons, but that's more miles to the tank.
Old Oct 26, 2011 | 02:09 PM
V10ZILLA's Avatar
V10ZILLA
I have a 09 F250 CC LB, it came with a 38 gallon tank. I have a V10. Try looking up a company called TRANSFERFLOW. They make all types of tanks for Diesels to replace your stock tank.
Old Oct 26, 2011 | 07:53 PM
tuscany's Avatar
tuscany
FYI on large tanks and no mileage run
https://www.ford-trucks.com/forums/1...esel-fuel.html
This is going to be my case.........
strokenboost
All Things Towing
33
Jul 4, 2017 07:43 AM
Urnmor
Jan 30, 2013 06:13 PM
twise
May 21, 2010 11:17 AM
Sleepsafe
6.4L Power Stroke Diesel
Mar 21, 2009 01:17 PM
snydermotive
Jan 16, 2004 12:38 AM
