HELP throttle issue
Old Oct 25, 2011 | 10:06 AM
renchr56's Avatar
renchr56
HELP throttle issue
Hello everyone. I have a 2003 F-550 w/7/3 auto trans. I have a guy broke down on the road that says he has no throttle response and the truck will only idle. I believe that it may be a fuse but not sure. Can anyone tell me what to check please
Old Oct 25, 2011 | 11:47 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
He needs to get the codes read. Sounds like the TPS (throttle position sensor) may have a bad connection or needs changing.
Old Oct 25, 2011 | 12:42 PM
Shake-N-Bake's Avatar
Shake-N-Bake
Another potential item to check is the OD wire from the shift lever. It can ground out in the steering column and blow a fuse that will cause the same symptoms.
Here is a nice write up by wood-n-things:
https://docs.google.com/viewer?a=v&p...M2Q5YjdmODQ4NQ
scbras
2004 - 2008 F150
Nov 29, 2010 10:54 PM
owenstout
Jun 22, 2009 07:43 PM
owenstout
Jun 22, 2009 05:28 PM
tfdcapt
Apr 20, 2008 12:59 PM
RanchRodsTX
1978 - 1996 Big Bronco
15
Nov 2, 2005 05:43 PM
