fusebox
Old Nov 29, 2010 | 05:23 PM
scbras's Avatar
scbras
fusebox
what is the number of the fuse of the throttle position sensor and would the gas pedal not work if there is one on the ford f150 4.6 motor 2004 year?
Old Nov 29, 2010 | 07:34 PM
danorules's Avatar
danorules
the map for the fuse box is in the drivers manual
Old Nov 29, 2010 | 10:54 PM
Dr. Rik's Avatar
Dr. Rik
a fused throttle?
The way the electronic throttle works is not procted directly by a fuse, it recieves it reference voltage from the (PCM). if you find your throttle is not responding check your codes, you are probably have a issue with the throttle body itself.
