Glow Plug Switch: MOD /with pics
Old Oct 26, 2011 | 01:07 PM
Talyn's Avatar
Talyn
Originally Posted by madpogue
A regular latching toggle switch, in series with the PCM wire, would do the same thing, without requiring holding it. Turn it on, wait (buckle up), start the truck, turn it off. If you forget to turn it off, the PCM turns it off anyway.
Gotta wonder, too, if it's really cost-effective. The PCM leaves the glow plugs on to make for a hotter combustion during the first seconds/minutes of engine run. It'd be about impossible to measure, but I wonder if, without the GPs, it burns more fuel during those first moments, and esp. if you use a Stancor relay and Beru/Motorcraft plugs, how much their life is really shortened by the PCM-programmed run.
The PCM will turn them on no matter what, so you shorten the life that way.
but it does assist during warm ups on cold start with combustion.
but for 2 mins max.
so...
Your not loosing a lot.
You'll just waste more fuel after you turn the GP's off till its warmer.
Old Oct 26, 2011 | 02:03 PM
madpogue's Avatar
madpogue
But by how much? Given a full set costs < $100, and the Stancor relay could last pretty-much forever, how much are you saving, versus how much extra fuel are you using by not running them? Probably impossible to calculate, but whichever way it swings, the net probably amounts to no more than a few tens of dollars per year.
Old Oct 26, 2011 | 02:04 PM
richdawg's Avatar
richdawg
KISS: You guys are giving me a head ache!! All this stuff I didn't even think much about. Interesting though.
Old Oct 27, 2011 | 12:09 AM
madpogue's Avatar
madpogue
^^^^ +1; and IMHO, the best "S" (simple) approach is to have a heavy-duty relay like a Stancor, known good quality GPs like Beru / Motorcraft, and call it a day.
sammie0126
Dec 18, 2020 02:36 AM
DeeDubz
6.7L Power Stroke Diesel
Oct 15, 2017 06:49 PM
TennesseeMustangPerf
Feb 18, 2017 09:23 AM
strokin'_tatsch
Feb 12, 2011 11:48 AM
ma94xlt
Feb 15, 2010 11:00 AM
