What tranny in my 59 C800?
1959 C800
4 spd manual with PTO on driver's side.
Trans code on data plate is K.
I found a 1960 decoder but it says that K is a Clark 5 spd, so that's not right. I assumed it was a T98A but I understand the PTO would be on the passenger side and I can't see a T98 stamped on the cover.
My 3-4 synchro is shot, so I need to figure this out and order the kit.
Thanks to whoever can help me out.
Originally Posted by josh_michels
206969
1959 C800 (C Series Tilt Cab) / 4 spd manual with PTO on driver's side.
I assumed it was a T98A but I understand the PTO is on the right (passenger) side and I can't see a T98 stamped on the cover.
1957/59: K = Clark 5 Speed Direct.
1960: K = Clark 5 Speed Overdrive.
1957/60: F = Borg Warner T-98 4 Speed Manual Transmission (C550/700 & F100/700 only).
1953/63: The T-98 was the only 4 speed available for any series of truck. But was not offered for anything larger than a C700, F700 and etc.
The T-98's PTO cover is on the right (passenger) side. Ditto: New Process 435 4 speed that was introduced in 1964.
The Clark 5 speed's PTO cover is on the left (drivers) side.
EDIT: 206969 is a CLARK 5 speed part number. While I couldn't find it listed in my 1964/72 Manufacturer to Ford/Ford to Manufacturer parts cross reference chart, I found others that are close.
Clark: 206967 = Ford: TFAA-7158-A .. Gear-Output Shaft-Fourth Speed / 21 helical teeth / 16 clutch teeth.
Clark: 206970 = Ford: TGAA-7203-A .. Transmission Gear Shift Lever Housing.
While these may not be your exact Clark trans part numbers marked on these parts, there will be other 6 digit Clark numbers marked on parts that begin with 20 - 21 - 22 - 23 - 28
So, are you saying I've had a 5 spd all this time and didn't know it? Honestly, I've never really tried to put it into fifth because the guy I bought it from said it was a 4 spd. Reverse is to the right and up. Is this the case with the Clark 5 spd? Would it be the Clark 265V?
The VIN is C80F9U26776. What engine does the "F" indicate?
Thanks again. I appreciate you guys with the resources taking time to help me out.
That's what I'm saying.
What truck 4 speed manual has the PTO on the drivers side? None that I'm aware of.
265V-59 5 speed Direct Drive.
F = 332 4V (Lincoln derived Y block).
9 = 1959.
U = Louisville KY Assembly Plant.
26776 = Numerical Sequence of Assembly (the trucks specific serial number).
The 1957/63 Ford Truck Parts Catalog is available on a CD from hipoparts.com.
faxonautolit.com has original and reprinted Ford owners & shop manuals, original sales brochures and etc.
I thought I would update this post with the shift pattern for this transmission. It might come in handy if someone else stumbles upon this thread for information. The pattern is a little atypical, but it makes sense for 1st to be where it is because it is ridiculously low. 7.58:1. Lower than reverse!
The link for drivetrain.com given by the user above does have the master bearing kit available as well as the synchro assembly (if you ask). I haven't bought any parts yet because I think I would rather just replace the synchro assembly than spend the money for a complete rebuild. So I'm still working on finding someone that will sell me just the synchro assembly and gasket kit.
BOWMAN SALES & SERVICE in Bowman ND has ONE = 701-523-3257.
WESLEY OBSOLETE PARTS in Liberty KY has ONE = 606-787-5293.
MILLER OBSOLETE PARTS in Binghamton NY has TWO = 607-722-5371.
GREEN SALES CO. in Cincinnati OH has FOUR = 800-543-4959.
C6TZ-7124-B .. Second/Third Syncronizer Assy / Obsolete
WESLEY OBSOLETE PARTS has ONE.
MILLER OBSOLETE PARTS has ONE.
FITZPATRICK & LAMBERT in Dushore PA has ONE = 570-928-8183.
FREESE MOTORS in Monticello IA has TWO = 319-465-3541.
BOWMAN SALES & SERVICE has TWO.
GREEN SALES CO. has FOUR.
A8TZ-7153-C .. Gasket Set / Obsolete
FREESE MOTORS has TWO.
BOWMAN SALES & SERVICE has THREE.
MILLER OBSOLETE PARTS has FIVE.
KINSEL L/M in Beaumont TX has FIVE = 800-816-2894.
GREEN SALES CO. has THIRTEEN.
D2TZ-4813-A (replaced B9QH-4813-A) .. Output Shaft Seal / Obsolete
WESLEY OBSOLETE PARTS has TWO.
MILLER OBSOLETE PARTS has THREE.
KINSEL L/M has EIGHT.
GREEN SALES CO. has THIRTY FOUR..
Obsolete parts prices can vary wildly from one source to another, so...
Call around for the low buck prices.
The VIN is C80F9U26776. What engine does the "F" indicate?C80 = C800 Tilt Cab.
9 = 1959.
9 = 1959.
Josh
Since you guys were so much help last time, I thought I would start here this time. We have the tranny out and we thought it would be a good idea to have an exploded view before we start tearing into it. Would anyone be able to point me in the direction of that drawing. As noted above, it's a Clark 265 5 speed.
Thanks,
Josh
Thanks,
Josh
Contact Green Sales Co. (greensalescompany.com / help number: 513-731-3304), ask them to scan and email the Clark 265 pic from this catalog.
I cannot give the the illustration section/page number, as I'm using a different version of this catalog.
3Bushwackers
04-29-2020 04:52 PM
1965GTFB
15
06-02-2017 07:49 PM
P38fighter
06-18-2015 07:39 PM
