spindle locking bolt
Old Oct 24, 2011 | 03:49 PM
jerryst's Avatar
jerryst
well i am finally going to put on disc brakes on my 55 f100. can someone tell me on the locking spindle bolts. which way do you knock out these bolts? do you hit it on the flat side or on the threaded side. i assume on the flat side is where you hit it to knock it out. the bolt didnt budge so i sprayed liquid wrench. and decided to ask before i go and destroy the bolt. thanks for all the information you can give give me.
jerry
Old Oct 24, 2011 | 04:57 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The threads are for the nut to pull the tapered (wedge) locking bolt into the hole. So you knock on the threaded end to push it out. Leave the nut flush with the top of the threads so you don't bugger them (but you may want to buy spares just in case).
Old Oct 25, 2011 | 01:37 PM
jerryst's Avatar
jerryst
thanks for the information on spindle bolt. Now if the liquid wrench did its job. knocking the bolt out wont be so bad.
Jerry
xtremexj
Aug 12, 2013 03:55 PM
1982_f150
Mar 30, 2012 06:45 PM
Snobord28
Oct 13, 2010 12:54 AM
GoCamping
31
Feb 26, 2008 09:19 AM
mds01
1978 - 1996 Big Bronco
Aug 4, 2005 01:20 PM
