EGR Valve reinstall
Old Oct 24, 2011 | 10:38 AM
kjackson's Avatar
kjackson
EGR Valve reinstall
I have pulled my EGR valve and cleaned it and am getting ready ro reinstall it. Are there any hints or tricks I should be aware of so I do not ruin the O rings. I have cleaned and vacumed the area the valve goes in and am using new O rings and gasket. this is a 2004 6.ol.
Old Oct 24, 2011 | 10:40 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Lubricate the o-rings
Old Oct 24, 2011 | 10:49 AM
cajunsuperduty's Avatar
cajunsuperduty
I always reach down in there and coat both seal areas with a light coat of high temp grease as well as lightly coat the orings. It should slide right down in there with just a little shove. You should also use a piece of scotch brite or something similar to polish the carbon build up off of the seal areas in the intake before you grease them. This will keep you from damaging your orings and make it easy to pull out the next time. I usually try to clean mine every 6 months or so. Just be sure not to drop anything in there and don't use anything gritty like emery cloth to polish the seal areas as it will get sucked right into the cylinders.
Old Oct 24, 2011 | 02:18 PM
kjackson's Avatar
kjackson
Thank you for the reply's I will use a lite coat of grease, but will have to wait until tomorrow went to the ford garage to pick up the o rings and they were out had to order some.
drzdave
Aug 6, 2014 03:11 AM
RKCORPS25
Oct 20, 2013 07:11 PM
bismic
Aug 27, 2011 02:14 PM
MAD
Aug 18, 2011 08:32 AM
bnmccoy
Sep 14, 2006 11:46 PM
