Door lock
Old Oct 24, 2011 | 10:27 AM
Redneck1465's Avatar
Redneck1465
Door lock
I have a 98 explorer with the keypad on the door. For some reason the lock does not want to unlock with the key. I know it is the right key and they keypad will unlock the door but I am looking to fix the lock just incase for some reason the keypad decides to stop working. Any ideas would be appreciated.
Old Oct 24, 2011 | 11:04 AM
aquanaut20's Avatar
aquanaut20
Lack of use and the mechanism has frozen, remove door panel and spray all pivots with PB Blaster... Philip
Old Oct 25, 2011 | 04:59 PM
Surge08's Avatar
Surge08
I bought an replacement for mine and built it to match my key.
Old Oct 28, 2011 | 03:08 PM
Redneck1465
How would you build it to match your key?
Old Oct 28, 2011 | 09:37 PM
shorod's Avatar
shorod
Starting with the new lock you can carefully remove the cover that retains the tumblers. Between the cover and the tumblers are springs so you need to make sure the cover doesn't just go flying off when releasing it. Once you have the cover and the springs removed from the new lock, do the same on the original lock once you remove it from the door. Remove all tumblers from the new lock, then hold your thumb over all but one of the tumbler cylinders, then carefully dump the tumbler and spacer out. Transfer them to the new lock, then move to the next cylinder, and so on. Do this for all 5 cylinders, then reinsert the springs and the cover. Try the key to make sure it works freely. Install the newly keyed, new lock in the door.
-Rod
Old Nov 6, 2011 | 08:11 AM
Surge08's Avatar
Surge08
You pick up a new lock cylinder from Ford. Include all new tumblers, springs grease and chrome/black key covers to match your truck. You set the tumblers to match your key. This process should only take 30-60 mins depending on experience
Old Nov 8, 2011 | 04:00 PM
jpmcglynn's Avatar
jpmcglynn
Or... if you don't want to mess with the tumblers yourself, just about any good locksmith can do this for you...
98greensi
2004 - 2008 F150
May 15, 2009 05:54 PM
tombob
1978 - 1996 Big Bronco
Nov 15, 2007 11:18 AM
dagren99
Jul 13, 2005 08:11 PM
JJAC
Nov 20, 2003 08:28 PM
MDK
1997 - 2003 F150
Sep 5, 2003 08:29 PM
