General Automotive Discussion
general motors dash problem
Old Oct 23, 2011 | 08:41 PM
racsan's Avatar
racsan
i do some minor mechanical work on the side and today i was doing a tune-up/oil change on a 2000 buick century sedan with the 3.1 , it has a digital odometer and along with it the shift selector indicator (PRND21) are not working, you cant tell what gear your in visually, and you cant tell how many miles the car has on it. all the fuses are o.k. and from what ive found online its a circuit board problem with the dash cluster. anyone else ran into this? everything else appears to work, it does have a c.e.l. and abs light lit up (dad has his code scanner right now, so i wasnt able to see what the c.e.l. was about)
Old Oct 23, 2011 | 09:34 PM
blkF250HD's Avatar
blkF250HD
I've seen a few Buicks with the dead odometer/gear indicator. We usually refer them to the dealer since it relates to the odo. As far as the ABS light, most common problem is a hub bearing starting to go, or an open in the wiring harness from each wheel speed sensor to the main harness. It will chafe and wear along the lower control arms in the front. GM makes a repair kit for it.
tjcprop
2004 - 2008 F150
Jun 14, 2014 12:05 PM
Larry Corp
Jan 24, 2014 03:05 PM
036.0stroke
Dec 19, 2011 09:06 PM
turboman24
Aug 18, 2007 03:33 AM
Hazell
1983 - 2012 Ranger & B-Series
Apr 28, 2007 09:48 AM
