question on upgrade?
Old Oct 23, 2011 | 11:56 AM
Rachetmaster's Avatar
Rachetmaster
I have 2006 f-350 4x4 with approx. 77,000 miles, I have been told by several mechanics that i should upgrade (or delete ) the EGR on my truck and step up my injectors (they refer to 70hp injectors ). I do pull a rather large 5th wheel trailer and haven't had problems other than that I would like a little more power with out loosing dependabity. Could I hear any feed back on this, I am not looking for "pro-street" truck but performance with longtivity and dependabilty is what i want.
Old Oct 23, 2011 | 12:28 PM
Dieselpop's Avatar
Dieselpop
To start with you need to find out the health of your motor get some gauges something like the Edge Insight CTS with pryo a must if you pull need to know temps ECT-EOT max spread is 15* i think if you are around 10* running on flat ground doing 60mph your cooler are starting to get plugged then a fuel pressure gauge under 45lbs at WOT kills injectors then if you go for a tuner have the money for ARP studs because it will happen. The add a coolant filter also a must to remove the casting sand. I pull a 14k 5er and have no problems.
pop
Old Oct 23, 2011 | 01:23 PM
2006powerstroke90's Avatar
2006powerstroke90
Why delete the EGR?
Tex will be in here, im sure commenting on this.
You need to monitor your temps ECT VS EOT and do all your maint properly and you will probably never have to do the EGR cooler or OIL cooler.
If you want to do anything do ARP's and bullet proof EGR cooler.
If you really want to add reliabilty to the truck do stand pipes and dummy plugs along with the STC fitting, and call it a day.
never have to worry about it again.
Old Oct 23, 2011 | 02:23 PM
BLADE35's Avatar
BLADE35
Better start studying you cant just upgrade Injectors like that with out upgradeing other stuff to
like ARP Studs, Turbo so its got enough air and maybe some fuel system upgrades
Id deleate the EGR I did mine and Gained 1-2 mpg I put in synthetic oil at the same time to so maybe a combo of both for the mpg gains
But with the EGR deleate your not putting HOT SPENT Air back inti the cylinders
The colder air is more combustable and Cleaner
Plus if the EGR Cooler is gone there is nothing to fail and alot less likly to hydro lock the moter
Im shure others will be along to coment
Regulator1988
Apr 2, 2012 12:15 AM
wildcat421
Oct 16, 2011 05:47 PM
exy
Aug 11, 2011 05:50 PM
carcus
Jan 25, 2011 08:10 AM
A-TUCK
Aug 25, 2010 01:49 AM
