Electric wiper motor replacement question
Old Oct 23, 2011 | 11:49 AM
Jolly Roger Joe's Avatar
Jolly Roger Joe
My 51 F4 came with an electric wiper motor, and that motor doesn't work. The available 6 volt "replacement" motor kit from LMC Truck does not look like the original assembly, and says it is a direct bolt in replacement for the vacuum motor.
LMC Truck Parts - Page 95
Since I've never seen the vacuum motor assembly, will this kit work with the wiper linkage in my truck?
Or better yet, does anyone know where I could get this original motor repaired?
Old Oct 23, 2011 | 12:53 PM
tinman52's Avatar
tinman52
Welder User
Beware of any retrofit electrical parts.......especially from LMC. I bought their wiper switch.....not even close to usable! Have you tested the motor? I tested mine with some jumper wires and a 6v battery. I got it to move, but it wouldn't work right until I got a good original switch hooked up. They also have 2 speeds.......
I would look around your area for an "electric motor rebuilder" or similar....
Old Oct 23, 2011 | 03:15 PM
Jolly Roger Joe
Yeah, I tested it. I found a couple of motor repair shops nearby. I'll check with them to see if they can work on it.
Do you happen to have a wiring diagram that shows that circuit of 3 wires off the switch? It's not on the diagram I have. I'd like to be sure I tested it correctly.
Old Oct 23, 2011 | 08:08 PM
tinman52's Avatar
tinman52
Welder User
Joe, I have never found a wiring diagram for the wiper switch. I had another harness intact that I just copied.....I should have made a diagram from it.
Old Oct 23, 2011 | 10:34 PM
51PanelMan's Avatar
51PanelMan
I also have the original switch with the wiring intact somewhere around here, but finding it amongst my mess of parts is like finding a needle in a haystack.
Old Oct 23, 2011 | 10:47 PM
Jolly Roger Joe
I did more research on this site, and finally figured, hey, this is just a motor with different taps for different speeds. So I tested it first with an ohmeter to see which was highest and lowest resistance (for coil size). And because someone on this site actually mentioned that the motor gets its ground through the frame mount, I no longer needed a wiring diagram to test the motor correctly.
I had to hit it with 12 volts to get it started. My first thought was that it's a 12 volt motor... but that can't be right because it's stock. When I hit it with 6 volts again, it ran... both low speed and high speed.
I opened the two gearboxes and cleaned the 60 year old caked grease. I replaced it with some high tech grease I use on rocket motor linings. Now the motor purrs like a well greased kitten... whatever that is.
I decided that since I was now keeping it, I should try to clean it up a bit.
Here's a pic after I removed it from the truck.
And after I checked it and cleaned it up a bit.
Now I need to check the wiring and the switch. Of course, it may work, since the 12 volt shock was needed to get it started.
Old Oct 23, 2011 | 10:50 PM
51PanelMan's Avatar
51PanelMan
When you're done, I'll send you two of mine to rebuild.
Old Oct 23, 2011 | 10:58 PM
Jolly Roger Joe
OK, but first let's see if I get the wipers working again.
By the way, have I mentioned lately that FTE ROCKS!
Old Oct 24, 2011 | 04:45 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Jolly Roger Joe
My 51 F4 came with an electric wiper motor, and that motor is shot.
A8TZ-17508-A .. Electric Wiper Motor / Obsolete / All 1948/52 trucks except F3 Parcel Delivery.
No Ford Dealer or obsolete parts vendor has any.
8C-17470 .. Wiper Switch-Use with A8TZ-17508-A wiper motor / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has ONE = 701-523-3257.
ANTIQUE AUTO SUPPLY in Arlington TX has TWO = 817-275-2381.
WESLEY OBSOLETE PARTS in Liberty KY has THREE = 606-787-5293.
Old Oct 24, 2011 | 08:13 AM
Jolly Roger Joe
Thanks Bill,
I have to see if I can make the old switch work, which probably won't happen until next weekend. Good to know they're still available.
Old Oct 24, 2011 | 08:57 AM
tinman52's Avatar
tinman52
Welder User
Thanks Bill,
Try to use the original if possible.....the repops that I have seen are not correct. My old switch works fine....
Old Oct 24, 2011 | 10:11 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The electric and vacuum wiper systems use completely different linkages.
There are all kinds of systems available to replace either the vacuum or stock electrical systems. A lot of people have fabricated adaptations of Cavalier, Jeep and other modern systems. It isn't easy to get the right sweep and still get it into place. 48-50's are really tough unless you hack the underdash braces. I'm going to make a system using parts from these guys this winter: Windshield Wiper Blades and Systems | DC Electric Motors | Wiper Motor Assembly | AM Equipment
Here is the wiring diagram.
Old Oct 24, 2011 | 11:26 PM
Jolly Roger Joe
Thanks for the diagram. I worked on it earlier this evening and checked out the switch, which works. Then I checked for voltage on the wires at the motor end, and got none. So I crawled under the dash to trace the wires from the switch, and discovered the power lead had been connected to a ground lug under the speedo. Same place a PO grounded the horn button they mounted to the side of the column.
I moved the power wire to the ACC side of the ignition switch, plugged the old wires into the motor, rigged a ground wire from the motor body to a frame ground, turned on the power, moved the switch, and got low speed and high speed.
What I don't understand is why it sometimes won't stop when I return the wiper switch to OFF. And sometimes, it won't start when I turn the wiper switch ON. But I'll figure it out.
Old Oct 25, 2011 | 05:58 AM
Oz52F1's Avatar
Oz52F1
Technical Wiper Option for 48-52 Ford F1 Pickup - THE H.A.M.B.
......coz vaccuum sucks!!!
Old Oct 25, 2011 | 09:08 AM
ALBUQ F-1's Avatar
ALBUQ F-1
Joe, check the grease inside the two gearboxes. On the one of mine I opened, all the grease had turned stiff and was around, but not touching, the gears. In other words there was a lot of grease but it wasn't doing any good.
As far as not stopping, there is a little button in the motor switch (on the motor) that rides a cam. That is the parking switch. Mine was really worn and didn't really break the circuit.
