Sponsored by: Auxito
Bad wheel bearings
Old Oct 23, 2011 | 07:14 AM
73fxe's Avatar
73fxe
Bad wheel bearings
When I bought My 02 the inner bearings where shot. I replaced the roters and the inner and outer bearings. abought 20,000 later the drivers side inner bearing went bad, I replaced both inner and outer bearings. 25,000 miles later I had the outer go out. Is this something anyone else has experinced? I did put a Timkins outer on it this time. Scott
Old Oct 23, 2011 | 01:13 PM
steve(ill)'s Avatar
steve(ill)
so you have a two wheel drive with individual bearings inner and outer...I would say if a bearing failes in 20k miles, that 99% of the time it either was adjusted too tight, or had no grease.
Old Oct 23, 2011 | 04:36 PM
73fxe's Avatar
73fxe
I put as much grease on and in the bearings as I can get so I would guess I tork them to tight. Thanks Scott
Old Oct 23, 2011 | 10:15 PM
steve(ill)'s Avatar
steve(ill)
the bearings on a 2 wheeel drive should not be "tight".. You snug up the nut to about 15 ft pounds to squeeze the grease and seat the bearings good. Then you back off the nut a flat so that the wheel rolls and spins easy. Grab the top and bottom and try to wiggle to see if there is any clearance in the bearings. There should be a small amount of wiggle or clearance, not snug. When they get warm and expaned, you dont want them to bind.
Old Oct 23, 2011 | 10:24 PM
galaxie641's Avatar
galaxie641
Also may have to pack the bearings before install, I think most come pre lubed now but doesn't hurt to pack them anyway.
brassplyer
Dec 9, 2018 10:45 PM
J ballan
All Things Towing
21
Jul 20, 2017 11:28 AM
C. Lee Colbert
1983 - 2012 Ranger & B-Series
Jul 3, 2011 12:32 AM
menzfamfour
Jul 25, 2007 09:46 AM
christaylor
Mar 25, 2004 01:41 PM
